      09-30-2020, 03:33 PM   #1
boobert23
Drives: 02 BMW M3
2002 M3 - Lang Built Motor, Active Autowerkes SC 458whp $21k
USD 21.00
2002 E46 M3
458 rwhp / 575 hp
Recent PPI done and full Liqui Moly service with 5-60.
Well documented car, all receipts available. No expense spared.
Approximately 2300 miles on the complete refresh/rebuild of this car. Still driven and will go up as it puts a smile on my face.
Adult enthusiast owned. Clean Carfax, southern car, ~3rd owner. Exceptionally well cared for and no expense spared. Over $50k invested in the last ~18 months.
Chassis has approximately 167k miles.
Car is mechanically flawless. Everything works exactly as it should. Free revving, fast and drives straight. Handles and brakes as good if not better than any car I have ever owned. Car is 'stupid fast' . (per my 13yo son)
All electronics work. Heat is hot and AC is cold. Brand new power top.
Engine:
Fully built long block, supercharged, meth injection.
*Lang Racing Long Block
- S54 Engine Long Block-Genuine BMW
rod bolts, rod bearings, main
bearings, main bolts, head gasket set
and main engine gasket set including
all O rings and seals, and all timing
chain and oil pump guide rails. Brand
new genuine BMW oil pump, modified
oil pump disk, VANOS seals, VANOS
plate seals, rebuilt solenoid pack, stage
1 performance cylinder head, CP
Pistons at 11.5 CR and 87.5mm
Bored, honed, hot tanked
- S54 Rod Bearing Journal Widening Kit
Including Crankshaft Journal
Modification (Supercharged Version)-
Modified S54 crankshaft, set of 6 rod
bearings, Carrillo rods - Crank: Lang
Custom, journal widening kit
- Upgrade to Stage 2 Cylinder Heads-
Supertech valve spring kit, high
performance 5 angle valve job
CAT Camshaft Set
DLC Coated Rocker Arms
Mishimoto Radiator
Power:
*Active Autowerke Supercharger
Gen9 Supercharger
Rotrex 92 trim - 7 psi
Oil Cooler
Gen7 Intake Manifold
High Flow Injectors
Dual Bypass Valves
Front Mount Air-Air Intercooler
Air Filter
Active Meth Injection
Turner Corsa Exhaust
Stopping:
*Wilwood Big Brake Kit F&R
AERO6 Front 14" 6 pot
AERO4 Rear 12.88 4 pot
Stainless Lines
Motul
Handling:
KW V2 Coilover Kit
Turner Front Camber/Castor Plates
Adjustable Rear Control Arms
E46 Rear Chassis/Subframe
Reinforcement Kit
- E46 Front Subframe Reinforcement Kit
Tuning
Protuned by National Speed
SMG Active Gearbox Flash
Exterior:
Brand new convertible top
Arch 8 Staggered Wheels
Brand new BF Goodrich G-Force Comp
2 Tires
Carbon Front Lip
Carbon Diffuser
Carbon Kidney Grills
Carbon Side Grills
LED Sidemarkers
LED Tailights
Tinted Fog Lights
Angel Eye LED Headlights
New 'M' Badging
Other:
Clutchmasters Clutch and flywheel
Autocraft AGM Battery
NGK Range 9 Plugs
Recent Alignment
Refreshed diff and pinion seal
New window motors
New Keyfob
Interior:
Aftermarket stereo with bluetooth
Factory Harman Kardon system
*Interior is decent but was the next project to tackle. It's all there and is presentable but it's not perfect.
Lots and lots of other preventative and reliability maintenance fully documented.
Other need to know:
A few small dents from hail on deck lid.
Rear ashtray cover missing
Covers on rear rollover protection system due to ugly stock headrests
Rubs slightly at very low speeds when at full lock.
Backup camera does not work
      09-30-2020, 03:36 PM   #2
boobert23
Drives: 02 BMW M3
Engine pics.
      10-09-2020, 10:20 AM   #3
boobert23
Drives: 02 BMW M3
bump - willing to wheel and deal. want to sell this car as soon as possible to help fund another purchase.
      10-12-2020, 09:18 PM   #4
boobert23
Drives: 02 BMW M3
SOLD
