09-27-2020, 04:05 PM | #1 |
Rep 6
M2 DCT problem
Hi everyone. Had somebody problem with DCT when turn on rear gear it turns on Neutral gear (malfunction code 40EC02)? You can turn selector to DRIVE but it turns only D2. If I restart my car, I can turn on ANY gear and it will be ok. Mileage is only 5000 miles, transmission oil level is normal. Thank you
Upd: problem was solved with full transmission oil and filters change Last edited by Exellion; 02-16-2022 at 06:51 PM.. |
10-06-2020, 05:57 PM | #5 | |
553
Rep 568
I am not at all familiar with Ukrainian law re: defective vehicles, but documentation early, often, and repeatedly is extremely important in the US. |
10-09-2020, 05:46 PM | #7 |
12809
Rep 3,616
Video that malfunction prior to your dealer trip so they can't put the' "Could not reproduce" $hit on you.
CalAcacian553.00 |
10-16-2021, 05:04 AM | #9 |
Driving Fast But Staying Calm
Rep 35
I have bought an used M2 pre Lci (N55 engine), and today I met this issue below (on video). I hit the R gear but my car didn't move at all, the light on knobb shift was on as in video below. Do anyone have this experience? Thank you
bmwclub.vn
page: https://www.facebook.com/groups/bmwccv.mem/?ref=share Last edited by kanz_min; 10-16-2021 at 05:09 AM.. |
10-16-2021, 01:40 PM | #10 |
Rep 224
Did you press the throttle? DCT doesn’t move until you press the throttle. It’s effectively in neutral till you do unlike a traditional auto
10-18-2021, 04:57 AM | #11 | |
Rep 35
Thanks
bmwclub.vn
page: https://www.facebook.com/groups/bmwccv.mem/?ref=share |
10-18-2021, 07:42 AM | #12 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
The gas pedal!!
Rick
10-19-2021, 07:13 AM | #14 |
Rep 35
bmwclub.vn
10-19-2021, 10:36 AM | #15 | |
1412
Rep 1,813
Sounds like an important error code. I would start there. Run some ISTA test plans for it. For the others, I would recommend reading codes first, instead of a video that may not help with anything, or be the same as the original user's problem.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
10-23-2021, 04:48 AM | #16 |
Rep 140
My guess is that the clutch that controls reverse and gear 1 might be shot. Could be a clutch pressure line fault or even a mechatronics issue. If you're lucky, just could be a reflash? Either way, this thing needs to go to BMW and get sorted out ASAP.
If it's not under warranty, maybe try reflashing the TCU? I'm also talking out of my a$$ |
