      09-18-2020, 08:06 AM   #1
aandriotis
Drives: 2004 bmw m3
2004 M3 Coupe Silber-Grau slicktop,smg
For Sale 2004 BMW M3 smg striper (slicktop, manual cloth seats, no nav)
Original California car I purchased it 3 years ago and drove it back to NY with no issues.
The engine and gearbox is very strong.
No accidents with clean NY tile in hand.
3rd owner
Service records and pictures of all the maintenance i did in the last 3 years.
Price:$22.000
VIN: WBSBL93404PN57905
Miles: 138xxx
Color: A08 silber-grau metallic
Upholstery: G8AT (Impulse Cloth non heated)
Gearbox: SMG
Maintenance & Upgrades:
Inspection II at 86k miles
-Oil change (Castrol full synthetic 10w-60 and OEM filter)
-Spark Plugs
-Valve adjustment
-Air filter
-MAF clean
Oil change at 90k miles
VANOS Overhaul (Beisan Kit) at 94k miles
-Thorough cleaning of all parts (electronic clear, solenoid activation, oil passages, seal and gasket surfaces, etc.
-Replaced all seals (VANOS unit, sealing plate, pressure valve, regulator valve
-Replaced the pump disc
-Replaced cam bolts
-Installed rattle kit and proper clearance adjustment
-Replaced upper chain guide and associated washers
-MAF clean
-Engine adaptation reset
-Valve adjustment
-Properly cleaned and lubricated all components
Inspection I at 101k miles
-Differential fluid (Castrol SAF-XJ)
-Transmission fluid (Pentosin MTF2)
-Engine air filter
-Cabin air filter
-Spark plugs
Preventative Maintenance at 110k miles
-Cabin air filter
-Fuel Filter
-Spark Plugs
-OEM differential drain/fill plugs
-Guibo
-Guibo hex bolt and self-locking nuts
-Center support bearing
-Diff bolt upgrade
Cooling Overhaul, Power Steering Refresh & Preventative Maintenance at 112k miles
- Turner Fluidyne Radiator
- Expansion tank
- Water pipe
- Upper & lower hoses
- Water pump (BMW)
- Water pump gasket
- O-ring (coolant pipe) x2
- Thermostat
- O-ring (t stat > water pump) x1
- O-ring (t stat coolant pipe inner & outer) x1
- Lower temperature sensor
- Turner Motorsport brass bleeder screw
- Power steering pressure hose
- Acc belt idler pulley
- Acc belt tensioner pulley
- Acc belt
- Drive belt tensioner pulley
- Drive belt
- Power steering flush
- Castrol SRF brake fluid flush
Oil change at 116k miles
-Oil change (Liqui Molly 10w-60 and OEM filter)
OEM BMW windshield at 119k miles
Inspection II at 121k miles
-Oil change (BMW 10w-60 and OEM filter)
-Spark Plugs (BMW)
-Coil Pucks (BOSCH)
-Air filter (BMW)
-Cabin Filter (BMW)
-Fuel Filter (MAHLE)
-Power steering fluid (Redline D4ATF)
-Brake Fluid (Porsche Racing)
-Differential Fluid (BMW 75w-140)
-Transmission Fluid (BMW)
-SMG Pump Fluid (BMW)
-Valve adjustment
Subframe reinforcement & suspension refresh at 121k miles
-Rear subframe reinforcement welded (Turner Motorsports kit)
-Strut tower reinforcement (BMW plates)
-Suspension (Koni Sport & Eibach)
-Subframe bushings (AKG 95A)
-Differential bushings (AKG 95A)
-Rear camber arms (Turner Motorsports Street/Track)
-RTAB (BimmerWorld monoballs)
-RSM (Rogue Engineering 65A)
-Transmission mounts (Rogue Engineering)
-Engine mounts (BimmerWorld)
-Front Sway bar (Hotchkis)
-FCAB (BimmerWorld TrackCAB)
-Tie Rods (Lemforder inner & outer)
-Valve adjustment
Oil change at 125k miles
-Oil change (RedLine 10w-60 and OEM filter)
Preventative Maintenance at 131k miles
-Oil level sensor (Hella)
-Rod Bearings (ACL)
-Oil pan gasket (BMW)
-ZHP Steering rack (Rack Doctor)
-Guibo (BMW)
-Center support bearing (BMW)
-Rear lower ball joints (Lemforder)
-Diff bolt (upgraded ones)
-Headlight bulbs Osram D2S night breaker laser
Oil change at 135k miles
-oil change (BMW 10w-60 and OEM filter)
Performance
Engine at 121k miles
-Euro Headers
-SAP delete
-HTE (Hassan tune) and SMG CSL tune
-Bimmerworld silicone throttle body boot
Suspension at 121k miles
Wheels & Tires at 115k miles
-APEX arc8 18x9.5” ET35 satin black
-APEX 12mm rear spacers
-Bridgestone Potenza S007A 265/35R18
Brakes at 115k miles
-Stoptech slotted rotors
-Stoptech SS lines
-OEM brake pads
Body
- Paint quality is excellent
- No Rust
-OEM CSL deck lid
-MIleEnd composites CSL diffuser
Interior
-Armrest delete
-Euro cupholder delete
-BAVSound full speaker upgrade
-AUX retrofit in glovebox
-Renline exact fit phone mount
I got all the receipts of the above and a ton more from misc items i took care over time
Still got the original trunk and US headers
https://photos.app.goo.gl/BdSA49M9ZVpZx6Dz5
https://photos.app.goo.gl/3myWggngiKHEnDHWA
      09-20-2020, 08:17 PM   #2
Nonstopjohn3
Nonstopjohn3's Avatar
Drives: Bmw M3 F80
2016 Bmw m3   [0.00]
Price:$22.000
Miles: 138xxx
Gearbox: SMG
-Spark Plugs
-Valve adjustment
-Air filter
-MAF clean
-Replaced cam bolts
-MAF clean
-Valve adjustment
-Engine air filter
-Cabin air filter
-Spark plugs
-Cabin air filter
-Fuel Filter
-Spark Plugs
-Guibo
-Diff bolt upgrade
- Expansion tank
- Water pipe
- Water pump (BMW)
- Water pump gasket
- Thermostat
- Acc belt
- Drive belt
-Spark Plugs (BMW)
-Coil Pucks (BOSCH)
-Air filter (BMW)
-Cabin Filter (BMW)
-Valve adjustment
-Valve adjustment
-Rod Bearings (ACL)
-Guibo (BMW)
Performance
-Euro Headers
-SAP delete
-Stoptech SS lines
-OEM brake pads
Body
- No Rust
-OEM CSL deck lid
Interior
-Armrest delete
Do you have a video of your ride like a walk around or start up
      09-20-2020, 09:52 PM   #3
IB M
2782
Drives: 2017 M3 MG/SO ZCP DCT
2017 BMW M3  [8.50]
2013 BMW M3  [10.00]
Impressive maint list. Did u put on 52k miles in 3 years or was some of the work done in Cali by the previous owner?
      09-21-2020, 06:13 AM   #4
aandriotis
Drives: 2004 bmw m3
previous owner did up the preventive maintenance (110k).
after that it was all me
      09-21-2020, 06:15 AM   #5
aandriotis
Drives: 2004 bmw m3
I will take one later
      09-24-2020, 06:02 PM   #6
aandriotis
Drives: 2004 bmw m3
https://photos.app.goo.gl/4AhPMMEqBFQA7rBHA
