07-11-2020, 01:38 PM | #1 |
Rep 938
BimmerCode: change Gauge cluster?
Hey all
My friend and I were using BimmerCode to change a few things on his m50i. While attempting to change the logo from m50i to just m, it changed the entire cluster layout. He no longer sees the gauges change when changing drive modes. I’ve never coded a g05 before but haven’t seen this. Any ideas on how to restore? Thanks! |
07-12-2020, 03:58 PM | #2 |
Rep 98
If you go back to the module you coded, there will be a backup button appear on the lower right of the iOS screen. All backups will be there and you can easily restore.
Also, when you code the M dash layout, it does still change the layout when you change drive modes, it is just very subtle. If you look at the lower sections of the dash, you will see a very slight change. I coded this layout onto my M50d but didn't like it. When I coded it back, the M50d badge was gone so I jus restored and all was well. Hope it works out for you. |
07-19-2020, 11:37 AM | #3 | |
Rep 938
