07-07-2020, 10:48 AM | #1 |
Rep 360
F30 320ix wheel alignment results
Hi,
Anyone able to tell me if these are good results? It took the garage two attempts to get the steering wheel straight as it was very slightly off centre. Car is in the UK so RH drive. If you've got your own for comparison chuck it up. Thanks |
07-12-2020, 11:34 AM | #2 |
Rep 205
Drives: 14 F30 335i xDrive
The after looks fine. Nothing alarming coming from that. Perhaps you took a couple hard hits before. But they did a good job getting it within spec. There's not a lot of toe-in in the front so turn in probably feels a little better. If the car feels good when driving, there's no pulling on the highway or when hitting hour brakes, then you should be good to go.
DG33073.00 |
