07-04-2020, 02:02 AM | #1 |
Rep 775
BBK/M-Sport Brakes - Yay or Nay?
Hi all,
I am considering moving from an M2 to M2 Competition and after some opinions around opting for the BBK/M-Sport Brake setup (optional in UK). These are my considerations so far: For: More stopping power. Haven't been overly impressed with my M2 in braking, even with RS29 pads. Better braking kit from factory means I don't have to notify insurance about "upgraded brakes" - bonus. A lot cheaper getting these from factory compared to buying separately. Against: More expensive from factory order. There are lots of complaints of the BBK kits causing stone rubbing/scraping on OEM wheels. Is it really 'that' bad? This car will develop into my go-to track car longer term. That said, I can always consider swapping out the brakes for aftermarket ones later on down the line to save on weight etc (also not prone to stone scraping). This unfortunately adds additional cost, notifying insurance etc. Thoughts? Experiences? Thanks all! |
07-04-2020, 04:09 AM | #4 |
Rep 775
Any issues with stones getting stuck against the calliper and scraping the wheels?
07-04-2020, 08:14 AM | #6 |
2091
Rep 3,008
There's no comparison though the blue brakes are good, the 2NH stopping power is another level.
I wouldn't say "a lot" of people have had a stone scratch the rim. If worried, get the blue then add an aftermarket option that give more clearance. |
07-04-2020, 08:33 AM | #7 |
Rep 739
Since you plan to track the car, get the blue brakes. Then remove them after you take delivery and throw on a BBK from Essex Racing. It's expensive up front, but your wheel and tire choices for track work will be 10 fold as you can run an 18" wheel. You will also save significant weight at each corner.
07-04-2020, 09:39 AM | #8 |
6643
Rep 4,145
Drives: '18 M2 6MT
If I was going to use this car as a track weapon there is no doubt in my mind that I'd have the BBS FI-R wheels because they're so light and strong. That right there puts the factory brake upgrade out of the question because it's super common to get those rock scores, and in the FI-R that means wheel replacement. Even for a daily I wouldn't have those brakes because of the stone scoring issue. Aftermarket FTW here. And as a bonus I believe all the aftermarket options are lighter (yes, I'm big on unsprung weight).
07-04-2020, 02:14 PM | #9 |
429
Rep 433
In the end it really comes down to your personal preference and budget.
It's very easy for us on the forum to spend other people's money How much extra is the 2NH brake option? How much tracking do you really intend to do? The 2NH brakes are heavier and limit you to 19" wheels which can be legitimate concerns, but as omasou mentioned they really do offer a significant step up in braking performance over the standard brakes. I have been very impressed with the 2NH brakes on my car so far after 7 track days with just basic upgrades (SS lines, new fluid, new pads and Ti shims) An Essex competition brake kit (front and rear) starts around $8500 (without pads) With options you're looking at $9000-$10000 That said, I do think they are one of if not the best kits out there for our platform BBS FI-R wheels start around $8000 With tires mounted and balanced you're looking at $9000-$10000 Although they look great and are super light, I believe they are only available in very limited sizes with less than ideal offsets (especially in the rear) 19x9.5" ET22 19x10.5" ET35 20x9.5" ET22 20x10.5" ET35 |
07-04-2020, 03:17 PM | #10 | |
Rep 775
07-04-2020, 04:07 PM | #11 | |
429
Rep 433
2000 miles on the stock 788M wheels and tires 3000 miles on 763M wheels and Cup 2 tires However, that doesn't mean it can't or won't happen as it has definitely happened to others Maybe I've just been lucky so far |
07-04-2020, 04:16 PM | #12 | ||
Rep 775
07-04-2020, 11:49 PM | #13 |
3179
Rep 2,577
As a blue brake user for 4 years, I must say it's useful enough under all conditions except for REPEATED lapping. With brake fluid (and pad if necessary) upgrade, it can handle quite a job.
Remember, brake disc is only a thermal tank, nothing else. Before disc heat soak, all the brakes, be it 10-piston 800mm Lamborghini Mars Edition, or the one found on Prius, can be programmed (via master piston configuration) to perform identically or very closely. I had experience with the 2NH brake, it instantly feels much stronger due to the larger diameter (larger brake torque arm). And I like it, despite of the fact that it's vastly more sensitive than a normal vehicle needs to be and thus can take some getting used to. However, the "bite" feel is just like the throttle mapping in engine tuning - you apply 30% and get responded with 50~60% output. Everyone has a different sensitivity point where they don't want more. 2NH for me is very close to that point. An over the top sample for me is the C63s amg ceramic brake, I had that and I hated it. It was so sensitive that normal tip-ins feels like an emergency stops. Not really able to drive normal with it. For some reasons, I didn't see many 2NH at track, nor did I hear complaints about it. I'm assuming the track guys automatically saves money, skipping it to go directly to aftermarket ones. But from what I've got from the blue brake, 2NH definitely can take seriously more beating before it gives up, and that would be good enough for the most track guys.
Lemania 2320
cptobvious2531.50 Robin_NL8734.00 |
07-05-2020, 12:15 AM | #14 | |
2248
Rep 1,694
07-05-2020, 03:56 AM | #15 |
Rep 1,477
Drives: BMW M2
The main reason I went for the BBK is to avoid those awful blue calipers. The massive monoblock calipers and rotors are also a joy for your eyes.
07-05-2020, 06:54 AM | #16 | ||
6643
Rep 4,145
Drives: '18 M2 6MT
07-05-2020, 08:30 AM | #17 | |||
2248
Rep 1,694
07-05-2020, 08:43 AM | #18 |
Rep 114
My experience @ 4500 miles.
3 out of 4 788s have wear marks indicating something was lodged between the caliper and the barrel. The rear marks have gone through the paint. The passenger front has a faint line. Never hear any sound that would have alerted me to an issue while driving. |
07-05-2020, 09:40 AM | #19 | |
6643
Rep 4,145
Drives: '18 M2 6MT
But in any case, I wouldn't buy the FI-R new for the track, I'd pick up a fringe set. I've seen 2 for sale since I got here just a year ago. The combination of those wheels, lighter tires, and lighter brakes would be fantastic on such a heavy car. |
07-05-2020, 09:48 AM | #20 |
2091
Rep 3,008
One more data point.
On the M2, I've had rocks get stuck in the backing ~5x. On the M2C, I think it happened once. Knock on wood, on the M2C, none caught between the caliper and rim. For me the initial bite of the 2NH was only a concern when I first bought the car. What I really like is how I can feather the brakes much better and when needed can stop on a dime. Just make sure no one is following too close. I had a guy lock up his brakes b/c I was able to stop so quickly. I wasn't going fast and he wasn't tailing me but my stopping definitely took him by surprise. |
