06-25-2020, 09:19 PM | #1 |
Member
76
Rep 69
Any issues running Bootmod3 Stage 2?
Hi all,
I just recently flashed BM3 Stage 2 ACN91 OTS map and while the car feels good, nothing crazy imo, most likely due to my limitations on CA gas, I just want to know that I can reliably have this on for the long haul. Is the stock HPFP able to handle this tune? I just wanted to see if anyone can weigh in on their experience with BM3 Stage 2; positive or negative. Has anyone had any issues so far that I should look out for? |
06-25-2020, 10:18 PM | #2 | |
7315
Rep 7,477
The ots maps are designed for the stock HPFP so it should have no issues. I cannot comment on how I feel about ots bm3 tunes since I do not use them.
06-26-2020, 08:59 AM | #3 |
24379
Rep 191,202
No issues as long as your car is FBO
06-26-2020, 11:31 AM | #4 |
Rep 391
I’m running bm3 stage 2 91 with full bolts ons on my N55 m2. No issues for 55,000 km’s so far.
I do interim oil changes at approx 9000Km’s between the scheduled ones. Also I do the plugs every 25,000kms. I’ve only had one problem to date, more fuel related though, than car related. I got a bad tank of fuel. Car wouldn’t run properly when jumping into the throttle. It would stutter and delay. Drained it for use in the lawn mower, then a fresh fill up at a different station and problem was mostly fixed. Ran that tank through and then the next tank was fine. Was good ever since (happened at least a year ago). When I go to track or autocross I add VP octane booster for added protection since those conditions are harder on it for intake air temps. If you are in Cali and have that shitty fuel, you might want to consider a good booster or other options to increase octane. I think bm3 also has a California tune for their fuel too, that would be added protection. Always look at logs to ensure it’s safe. And if it doesn’t run right, stop and assess things, don’t run it and hope it’ll clean itself out. I think fuel is your only risk provided you meet all the fbo needs. |
VisualEcho6642.50 |
06-26-2020, 11:08 PM | #6 |
Member
76
Rep 69
Thanks all for the feedback and assurance.
I am FBO and plan to do plugs on my next service. But ya'll are right though, logging is the best way to adequately ensure the car is running well. I was holding out because, without a dyno, it really isn't the easiest/safest thing for me to do. That being said, I did manage to do gather a few logs this early morning and sent them for review. They will be updating me on Monday |
06-28-2020, 10:39 AM | #7 |
Rep 1,389
Turbos have been fine on stage two? I ask as thought stage of tune is almost a 'stage three' in stock M2 N55. Sure I read that here.
That initially tuners could only get a bit more out of the OG M2 then a year or so later stage two tunes cracked the 410/420 bhp mark weirdly. I realise 'stages' get a bit non specific usually past stage two. |
