Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums AUSTRALIA Been busy sorting charging cables
      05-31-2020, 01:36 AM   #1
Slideit
Slideit's Avatar
49
Drives: BMW 330e
Spent the afternoon drilling into garage wall to hang the charging cable, aimed for it to be out of the way, but also reach the charging port on the car irrespective of parking orientation.
Now just need a windy day to test how well I did!
      05-31-2020, 02:06 AM   #2
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
Very industrious, but can I suggest you change the wall power outlet to a proper outside version that is waterproof. I’m not sure the one you have at the moment is legal......at least not here in South Australia.
G20 M340iX, Sunset Orange, Tartufo Merino Leather, Pretty Well Loaded, OEM Aero Kit, Drive Recorder, BlackVue Dashcams removed and replaced with ACE 2.0.
      05-31-2020, 03:07 AM   #3
Slideit
Slideit's Avatar
49
Drives: BMW 330e
When I had it installed, that's what I asked for. But the electrician told me I won't need that because it's fairly well shielded (it's under cover in this spot. I got an certificate for the work, so I that should mean it's all legal!
      05-31-2020, 04:30 AM   #4
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
All cool then. That’s good.
How long does the car take to charge from near discharged to fully charged?
Have you had a chance to test what range you can get on pure battery?
I would imagine your combined fuel economy is pretty low.
      05-31-2020, 05:04 AM   #5
Slideit
Slideit's Avatar
49
Drives: BMW 330e
After 123km, with a few runs intentionally running the ICE (Sport mode) so I get some running in happening:
Combined range is around 450km (as reported by the app)
Full battery reported range is around 40km
I can charge at a max of 8amps, which should fill it up in about 5.5 hours, but by calculating the rate for partial charges , looks like a full charge would take around 8hrs.
It’s been hard to go and do a proper test, hopefully over the next week I get do a full electric range test.
g20
