BMW X5
      05-28-2020, 02:19 AM   #1
dds007
dds007's Avatar
Drives: F95, F97, F85, F82
Does your heads up display change when "M" button is hit?
Every YouTube video I've seen and my previous experience with M-cars all indicate that the Heads-Up display changes when the M button is hit?
The only way I can get it to work is if I hit M Mode by the shifter. I can't even preset it as part of the M1 or M2 buttons.
On a side note, anyone know what the L2 button on the driver's side door does?
      05-28-2020, 06:54 AM   #2
GlennC
GlennC's Avatar
Drives: '21 GLE 63S
Same here re the M display and I can't figure out the L2 button either even after just having a quick look at the owner's manual. Not a very helpful response but at least you know you're not alone.
dds007411.00
      05-28-2020, 09:07 AM   #3
puckybadger
Drives: 2024 X6 M60i LCI TBII/Tartufo
It is not an L2 button, it is a visual of a seat with the #2 so the driver can adjust the passenger seat for their guest. This feature is clearly shown in the owners manual.
GlennC321.00
      05-28-2020, 09:40 AM   #4
AwesomeM3
AwesomeM3's Avatar
Drives: F95 X5MC
2015 BMW X5 M  [10.00]
2020 BMW X5M Compet ...  [0.00]
2008 M3  [10.00]
Does anyone have a pdf of the F95 X5M owner's manual they would like to upload?
2020 F95 X5///M Competition CarBahn Autoworks Stage 1 | 2023 Lamborghini Huracan Tecnica
      05-28-2020, 10:45 AM   #5
dds007
dds007's Avatar
So do you position passenger seat and hit SET > L2?
      05-28-2020, 02:34 PM   #6
VTENGR
1053
Drives: 2020 X5 M50i
No, you push L2. That now gives you control over that seat from the drivers seat control. Once you have it set, you can program that position while L2 is still active by using the memory buttons on the drivers door.
dds007411.00
      05-28-2020, 03:55 PM   #7
LexxM3
LexxM3's Avatar
1699
Drives: E46M3, G05X5
2019 X5  [0.00]
No, press L2 and while indicator on L2 button is lit, adjust passenger seat with driver seat controls, including the 1 and 2 buttons. I don't actually know whether you can set passenger recalls 1 and 2 from drivers side, but you can activate them when L2 is lit.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
dds007411.00
      05-28-2020, 06:02 PM   #8
dds007
dds007's Avatar
Thanks guys! Helps a lot!
xbimmers
