05-03-2020, 08:22 PM | #1 |
Mr Bill
296
Rep 545
Tow Hitch
FYI the Draw Tite hitch for the M40I will work on the X3M as well.
https://www.etrailer.com/Trailer-Hit...ID=20185002428 I installed the Curt version which required a bracket to be cut and a hole to be drilled but otherwise fit well. The Draw Tite one would be a complete bolt in. Much cheaper alternative to Stealth Hitch if you don't want to go that way. Also the towing plug is still there as it was in the M40i I had, so I suspect the BMW wiring harness would be a bolt in and could be coded in to recognize the tow hitch and adjust stability control, etc...
2018 GLC63
2016 Miata 2020 X3M (sold) Turbo Miata Racecar (sold) 1995, 2009, 2015 M3 (sold) |
05-04-2020, 08:02 AM | #3 | |
Rep 1,406
Drives: 2020 SO - M2C
05-04-2020, 12:29 PM | #4 |
Mr Bill
296
Rep 545
In all honesty, I picked the one I did by accident. I thought I was picking the M40i version, but just screwed up.
Because of that I had to cut off one small tab and drill a hole. For me not a big deal, but I have all the tools to do this easily. In the M40i version there are no side plates where I had to drill this one, so it would be plug and play. It wasn't worth me buying the other one for another for $180, I just modified this one to work for me. The good news is I trimmed absolutely nothing on the car and it fit pretty much perfectly other than the mods I had to do because I goofed on ordering.
2018 GLC63
2016 Miata 2020 X3M (sold) Turbo Miata Racecar (sold) 1995, 2009, 2015 M3 (sold) Last edited by bracer; 05-04-2020 at 12:38 PM.. |
shemeld_135652.00 SRHinVA36.00 |
05-04-2020, 11:52 PM | #6 |
Mr Bill
296
Rep 545
4400lb if in the USA, 5500lbs in the rest of the world.
For me I tow a 2000lb Miata on a 800lb trailer, so not a big issue.
2018 GLC63
05-06-2020, 09:46 PM | #8 |
Rep 617
I installed the Stealth Hitch myself, it's not hard. It took me about 3.5 hours taking my time. A shop should be able to do it in half the time I did. They'd also be use to popping trim pieces off and should do a good job.
05-06-2020, 09:49 PM | #9 |
Rep 1,221
I'm no grease monkey and have installed the stealth hitch on my own without issue. Just RTFM closely and you'll be fine. The reason the euro hitches rate higher than their US equivelants is the hitch itself. Euro hitches are solid with zero play from the vehicle frame to the ball where the trailer or accessory attaches. American hitches, in contrast, use a receiver with a locking pin which introduces some Y-axis play during acceleration and deceleration which in turn lowers the overall towing capacity given the increased forces transmitted to the body of the vehicle in those situations. The stealth hitch mimics the euro concept offering a solid connection to the ball. That is unless one opts for their standard receiver solution which results in maximum versatility for receiving different hitches with different sized balls at the cost of slightly lower tow ratings. I purchased both: a fixed ball with a higher capacity for all of the things I own and tow as well as a standard receiver in case someone asks me to tow a different ball size than what I run. Ciao
05-07-2020, 08:31 AM | #10 |
Rep 999
I have the Stealth on mine and absolutely love it. Use their site to find an Authorized Installer near you and see what they charge. One local to me did it for $350 and was worth every penny! GL
08-16-2020, 01:52 PM | #12 | |
Car guy
1041
Rep 1,323
08-16-2020, 06:16 PM | #13 | ||
Rep 608
08-17-2020, 09:33 PM | #15 |
Rep 102
Does the US not get the option S3AC which is a fully invisible trailer coupling that swings out electrically at the touch of a button?
08-17-2020, 11:06 PM | #16 | |
Rider and driver
141
Rep 506
Something to do with NHTSA perceptions.
2021 X3 MC
I work for Keyser Söze |
08-18-2020, 09:08 AM | #17 |
Rep 192
Their price seems to jump all over the place. It was around $230 a few months ago & I didn't buy it then. I'm hoping it comes down a bit before I pull the trigger. I find that I get super cheap on the less expensive stuff!
2021 Cayenne GTS * 2021 AMG GLE 63
2019 911 Targa 4 GTS, Carrara White Metallic 2008 911 Turbo Cab, Speed Yellow 1997 911 Targa, Zenith Blue 2017 GT3-RS Lava Orange (LEGO) |
08-18-2020, 09:45 AM | #18 | |
Rep 608
Macanakey138.50 |
08-18-2020, 12:32 PM | #19 |
Rep 192
Would you mind sharing link? I see several options there. Not sure which is the right one.
08-18-2020, 12:39 PM | #20 | |
Rep 608
Draw-Tite 76226 Max-Frame Class III Receiver Trailer Hitch for Select 2011 and Newer BMW X3 https://www.amazon.com/dp/B07D7GS11C..._oibpFbJSBV727 |
Macanakey138.50 |
08-20-2020, 01:56 PM | #21 |
Rep 192
Last Q for now - does installing one of these units affect your ability to open the hatch with the foot-kicky motion? I do love that feature on the car.
08-20-2020, 02:16 PM | #22 |
Rep 1,397
Drives: 2020 X3MC
I can never get mine to work. Any trick to it? I read the manual and did exactly what it says - put foot under the bumper then pull it back quickly - and it still works sporadically.
