Technical Sections Suspension / Brakes / Chassis
      04-27-2020, 07:23 AM   #1
Haagen-Dazs
Drives: Apollo 13
e46 M3 Big Brake Kit Options
Hi friends,
As some of you may know, I’m doing a project with my recently purchased M3. I’m also recording everything for my YouTube channel (linked bellow).
https://www.youtube.com/channel/UCBd...8fg0jc7bGTs_Jg
At the moment I’ve got D2 racing brakes, at the front, but I’m equating installing a new set front and back.
Here in Portugal there are a couple M3’s running 6 pot Stop Tech brakes, and they appear to be quite good.
I’ve thought of Stop Tech, AP Racing and Brembo.
I would appreciate a bit of feedback, possibly with part numbers and personal experience, about BBK for the beloved e46 M3.
Thank you so much for your help!
bplus0.00
      04-28-2020, 12:18 PM   #2
Gt4
Gt4's Avatar
54
Drives: 2006 E46 M3 Estoril blue 6mt
Depends what’s you are going to do with that BBK; street or track?
In the past years, I had Stoptech St40, AP Racing 8350, Performance Friction z45/Z29.
For track use, I prefer Performance Friction BBK.
For street use, Stoptech is really good cause rotors and pads aren’t too expensive.
      04-28-2020, 03:51 PM   #3
Haagen-Dazs
Drives: Apollo 13
90% road. I’ll be doing 5-10 track days per year, at most...
AP have good rep and are from England, which is nice since I’m in Portugal. No idea about replacement pads and rotors
      04-28-2020, 09:47 PM   #4
sc_tr0jan_m3
sc_tr0jan_m3's Avatar
519
Drives: 2018 Grigio Telesto F80 M3 DCT
I go about twice a month and still use the oem caliper setup. I just have pfc08 pads and endless 650 fluid with SS lines. I'm still able to manage my brakes without any issues.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
2004 Titanium Silver E46 M3 6 Speed | :: Track Car ::
      04-29-2020, 06:38 AM   #5
Gt4
Gt4's Avatar
54
I also track during 3 years on my first E46 M3 with OEM calipers setup, PF01 pads, SS lines, Motul 660 fluids, brass guide pins bushings, front brake ducts, ...
But there are advantages to get a proper track BBK:
-thicker pads and bigger surface
-thicker rotors and 2-pieces design help dissipate heat
-pads wear out evently, not like a wedge like OEM sliding calipers
-big weight reduction, less rotational weight/unsprung weight
      04-30-2020, 08:02 PM   #6
sc_tr0jan_m3
519
I don't disagree!
I'm likely to bite the bullet and upgrade to an AP setup for next season... but I'm also doing that while acknowledging the huge upfront cost that could be spent on more track days instead of fancy calipers.
For the majority of the HPDE crew an oem setup with good pads, fluids, and lines is more than enough.
      05-01-2020, 12:37 AM   #7
Gt4
Gt4's Avatar
54
I don't disagree!
Well BBK pads cost usually less for same compound than oem pads shape so in the end after several sets BBK is paid by itself!
      09-21-2022, 08:53 AM   #8
zmicke
Drives: M2 Competition
https://freakyparts.co.uk/collection...-big-brake-kit and Csl discs.
      09-22-2022, 12:48 PM   #9
Bent_remy
Enemy of viscosity and thermal breakdown
Bent_remy's Avatar
Drives: N54 E93 6MT
Have you considered the E31 front and 996 rear caliper conversion?
02' E46 S54 M3 6MT OEM+, Apex FL-5,
RIP 09' E93 N54 6MT, Smarttop, Lux V5, JB4 G5 ISO, BMS DCI, Black ER CP, Tial BOV
      11-17-2022, 07:54 PM   #10
simpleM3
simpleM3's Avatar
165
Drives: 06' E46 M3 ZCP
19’ BMW M5C  [0.00]
2007 E61 530XI  [0.00]
2006 E46 M3  [0.00]
Can anyone provide reviews on this setup? I’m interested, but based on my understanding, the e31 fronts are for non-ZCP calipers.
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell
03' E39 M5 | 100% Stock
      02-01-2023, 07:25 AM   #11
Bent_remy
Bent_remy's Avatar
Drives: N54 E93 6MT
Check out the build here:
https://thebuildjournal.com/diy-inst...-retrofit-diy/
"Great thing about the E31 caliper is that it’s 100% bolt on to the stock E46 M3 (non ZCP) retaining the 325x28mm rotor size." I plan on going this route. I've already picked up new rotors and pads from R1 concepts. I'll be sourcing the E31 calipers from Turner motor sports and the 996 calipers from Ebay or Rennlist in a few weeks.
      02-15-2023, 10:59 AM   #12
torvektheo
torvektheo's Avatar
Drives: F25 X3; 981 Cayman S
Depending on your application, your may have to spend big $. But for occasional track, I would recommend what I installed on my e46M3.
F25 X3 35i
981 Cayman S 6speed
Past Cars:
02 E46M3 SMG; 98 E36M3/4/5; R56 Cooper S 6speed
17 ZCP F80M3; F36 435i; E93 335i; E46 330Ci 6Speed
