Technical Sections Suspension / Brakes / Chassis
      04-03-2020, 09:35 PM   #1
eljay
1444
Drives: ///M + E91
Brake upgrade options
I am not in a rush to upgrade my brakes, but at some point in the near future, I will be replacing my ZCP rotors, hence my contemplating an upgrade.
I think I will be staying with my stock ZCP brake setup and I also have a set of 17" Apex wheels still in boxes that I planned to use for track days, but that has not happened yet.
So, what are the options these days that would be a mild upgrade and also allow the use of 17" wheels?
Thanks.
      04-04-2020, 01:23 AM   #2
F806speed
Drives: BMW
I would suggest some aggressive pads, stainless steel brake lines and new brake fluid.
      04-04-2020, 03:24 PM   #3
eljay
1444
Drives: ///M + E91
That's probably a wise advice.
I have StopTech Street Performance pads on now and I'm happy with them. For track days, I will look for something better when I get new rotors.
Brake fluid is RBF600 just because I had some on the shelf. It will need flushing before any autosport outing I'm sure as it will be a while.
Thanks!
      04-06-2020, 09:19 PM   #4
sc_tr0jan_m3
sc_tr0jan_m3's Avatar
519
Drives: 2018 Grigio Telesto F80 M3 DCT
i run the OEM, non-zcp brake setup with PFC08's on blank rotors, SS lines, and endless fluid. holds up pretty awesome at the track.
2018 Grigio Telesto F80 M3 DCT | :: Bone Stock ::
2004 Titanium Silver E46 M3 6 Speed | :: Track Car ::
      04-12-2020, 07:32 PM   #5
Andrew
Moderator
Andrew's Avatar
429
Drives: E46 M3 / E92 M3
2003 BMW M3  [0.00]
2008 BMW M3  [0.00]
eljay
If you want a caliper upgrade, the best value is the Aston Martin DB9 front caliper and Porsche 996 rear calipers. Best part, it uses your CSL/ZCP rotors. Just an option.
Otherwise a pad upgrade and stainless steel lines will be plenty for street and mild track use.
[Track] 03 AW/CIN 6MT E46 M3
[Street] 08 AW/FR 6MT E92 M3
[Tow/Overland] 23 Toyota Tundra HV TRD Off-Road
      04-13-2020, 09:48 AM   #6
eljay
1444
Drives: ///M + E91
Originally Posted by Andrew View Post
eljay
Thank you both.
That's a nice caliper upgrade option!
I think after all the couch racing in my mind, I will stick with my ZCP calipers and get new OEM rotors. Some better pads may be the best option for my situation as I will likely not see much track time in the foreseeable future, so there's no need to snowball a sinple rotor replacement.
I already have SS lines and 17" Apex wheels, so I think after new rotors and pads, my money is best spent on some sticky 255/40R17 tires and go have fun when the opportunity returns.
If my talent outruns this hardware, I'll know the money will be well spent on the above options.
