02-19-2020, 09:22 PM | #1 |
Rep 68
BMW 340i M Performance Brake Kit issues
I just took my 340i with the m performance brake kit into my BMW service center because the front brakes are starting to squeal a little bit after about 18,000 miles. The service center advised that the front pads are down to 3.5mm and BMW recommends replacement below 4mm. They further advise that my rotors show evidence of grooving and have a lip at the outer edge. BMW will not resurface the m performance rotors amd that they are a one time use item and they will not put new pads on without replacing the rotors. After vigorously questioning this they advised that if they could get the service manager to agree to changing out the pads only they would only do so If I agreed to release them from any liability and warranty provisions because they deem this course of action to be unsafe and against BMW policy for this brake system. So in essence they want me to replace the pads and the rotors for roughly $1500 per front axle. Does this sound right to those who own or are familiar with the m performance break kits.
02-19-2020, 09:33 PM | #2 |
Rep 805
I would agree with what they are saying is best to do. Cutting brake rotors is bush league and only works for a couple months. The pads and rotors bed in together I always replace them together.
You can get an aftermarket set of pads and rotors for around $700. It's easy to do it yourself or pay the guy 800 to do it, and save yourself the time and hassle. I think that's fair. I have a new set of OEM pads from that kit if you want, 75 shipped. Weird that you've worn them down that much, are you slamming on the brakes all over town / did you code the DSC .. it may be heavily front biased if you didn't code it, I don't know what the coding _actually does. |
02-19-2020, 09:46 PM | #3 | |
Rep 68
02-19-2020, 11:18 PM | #4 | ||
4027
Rep 3,541
Here's what BMW's procedure explicitly says: Quote:
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
02-28-2020, 07:43 PM | #5 | |
Rep 68
02-28-2020, 09:17 PM | #6 |
Rep 44
There’s a difference between the M sport & M Performance brakes, If your car is equipped with Blue brake calipers then it has the M sport brakes... M performance brakes come with slightly larger rotors & only come in Red, Yellow, Orange calipers! Something to keep in mind.
02-29-2020, 02:17 AM | #7 | |
Rep 68
lonewolfB5818.00 |
02-29-2020, 03:18 PM | #9 | |
1599
Rep 3,748
There is nothing wrong with the m-sport or m-performance brakes. Performance option tend to make dealers think they can charge way too much $$$ |
lonewolfB5818.00 |
