02-14-2020, 01:21 PM | #1 |
Don't Fear the REAPER
11
Rep 89
Opinions/Suggestions: 2016 320i Xdrive brake upgrade
Just picked up my first and not the last BMW, its a 2016 320i Xdrive. Can the veterans/experts here give me there opinions/suggestions on BRAKE caliper upgrade from stock?
**I don't need suggestions on selling the 320i and getting something else, I really just would like some good information pertaining to this subject.** INFO: The car is a daily driver, I do not plan to track the car, I do enjoy SPIRITED driving from time to time and looking to upgrade to improve, enhance, upgrade, and better aesthetic look from plain old stock calipers. Upgrading also to 18" wheels. PROS and CONS of the M Sport Performance 370 calipers vs M Sport 340 calipers. Caliper cost? Brake rotor cost? additional parts cost to fit my car? Availability? Last edited by rob21sf; 02-15-2020 at 07:02 AM.. Reason: update info |
02-14-2020, 09:34 PM | #2 |
NewFinishColumbia/detailer
604
Rep 2,096
Depends on what you plan on doing with your car really. Daily, track, both, canyon drives, how experienced you are as a driver.
We need more info.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
02-14-2020, 11:06 PM | #3 |
994
Rep 1,934
There are countless threads, recent and old. Do some searching and reading, then come back with a specific question.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
02-15-2020, 03:24 AM | #4 | |
4541
Rep 5,400
There are folks on here trying to enhance their rides with better than stock parts, all the way to those whose imaginations & budgets seem to have no limits. HaHa, I won't give away where I fall in that range. Are you trying to enhance braking on your daily driver? Are you planning to heavily modify and perhaps even track your car on weekends? Is your priority to have brakes that look nice or are a different color? Are you planning to install any of this yourself? What's your budget range? I could recommend better brake pads to install yourself for $200 that might meet most of your braking needs. Or I could tell you to spend $2,500 or more to get an M Performance Brake kit installed. Did you just gag on that price or did you actually start to consider it? A limiting factor is whether you have 17" wheels or 18" wheels. Some F30 brake calipers require a minimum of an 18" wheel to fit. You can still fit awesome brakes under 17" wheels. Wheel size is just a design factor that has to be known from the beginning of the project. Hope this helps! |
02-15-2020, 06:57 AM | #5 |
11
Rep 89
Pardon for leaving this bit of detail out. My car is a daily driver, I have no plans to track the car, I'm mainly looking to enhance, upgrade, and improve aesthetics of the brake calipers. I am a true believer in "it's better to have and not need that to need and not have" when the time comes!
I am upgrading the wheels from the stock 17" to 18", adding H&R springs, and stage 1 piggyback for now. I'm being realistic when it comes to HP potential since it is a 320i. I guess I'm wondering if the M Sport Performance 370 calipers versus the M Sport 340 brake calipers is overkill for what I'm trying to do. |
02-15-2020, 11:24 AM | #6 |
1599
Rep 3,748
M-perf 370mm and 345mm... some 18" wheel clearance issue (aftermarket)
M-sport 340mm and 330mm... a little cheaper. Will fit on 18". Some clearance issue for 17" BREMBO GT .... you have money do it for looks STOPTECH big brakes.... why? Cheapers upgrade for you is run high friction brake pads. Will damage rotor faster but it make your car stop faster. |
