11-01-2019, 05:29 PM | #1 |
311
Rep 401
Pre-owned Florida car
I am looking at a 2014 car located in Naples Florida. Curious if any Florida residents think salty ocean air is a corrosive issue for cars? It’s a fairly high-end car, and I presume it has been garaged, as it appears in excellent shape. But just wondering if this should be a concern to me?
02-18-2021, 02:40 PM | #2 |
630
Rep 433
Eventually, corrosion will occur, yes - but BMW has a standard 12 year corrosion warranty.
My view is that as long as it checks out (no accidents), and is clean/good in every other way, you should be good to go with a 5-6 year old used car (with maintenance/having to replace crap as needed... might want to look into an extended warranty if it's offered?) |
02-18-2021, 03:42 PM | #3 |
Rep 290
Drives: 2021 m550i
If the residence the car was parked at is next to the ocean (waterfront property), I have seen corrosion occur on various cars within a couple of years. Otherwise, it should be fine.
03-24-2021, 08:10 AM | #5 | |
1592
Rep 4,554
OP, find out the address where the car was parked and look it up on Google maps. If that's not an option, I highly suggest inspecting the underside of the car, specifically suspension components, wheel hubs, exhaust, etc. As well as under the hood. Also, if the tire valve stem caps are missing very likely the valves may need to be replaced. I've seen the tire valve issue many times. Sometimes the corrosion gets so bad you can't add air to the tires.
2023 840GC | 2021 740i | 2019 X3
03-26-2021, 05:40 PM | #6 | |
2027
Rep 2,951
Drives: 2020 BMW 530xe
03-27-2021, 07:36 AM | #7 | ||
1592
Rep 4,554
I suppose if you live coastal, and had rust through, they would cover it. But they'll likely stick by the terms for parts with surface rust that haven't rusted through.
LogicalApex2027.00 |
