BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Bmw F20 F30 N13 heat shield rattle fix DIY
      10-01-2019, 11:34 AM   #1
maupurr
Hungary
Drives: Bmw F20 116i M Sport
Hello everyone,
I would like to share my solution for the really disturbing heat shield rattle issue, which affects Bmws built with the n13 Prince engine. The cause of the problem is that the metal shield warps due to the regular and excessive heat load and therefore comes into contact with the downpipe as the engine vibrates.
Here's a reference video of what I am thinking of (not my video):
At the dealership they only offer to change the complete heat shield for tons of money. As you can see on the following diagram the whole part is mounted with three screws only to the outlet manifold which is a really dumb design:
I came up with a solution which is not very refined, but cheap and easy to implement. I just call it the toilet paper method
All you need is:
  • Approx. 2 meters of 2 mm thick heat resistant fiberglass wrap. It is generally used for insulating downpipes. These wraps are heat resistant up to a 1000 degrees Celsius so they can easily handle the heat load. Here's a link: link
  • 1 piece of stainless tie
  • Hook cutter
Instruction:
All you want to do is rolling up the wrap in several layers onto the oil pipe (no. 8 on the diagram) which is located next to the heat shield. Thus the wrap will jack up the heat shield into the right position. Then apply a stainless tie on it in order to prevent it from coming apart. Cut off the overhanging part of the tie.
(The oil pipe is mounted to the chassis so it shouldn't be a problem to take such small amount of load.)
Hints:
Use gloves when touching fiberglass as it can be stingy.
Only work on your car when the engine is cold.
For me it works perfectly. Altough I have only made just a couple of hundred kilometers since I have installed the wrap.
      06-11-2020, 11:31 AM   #2
evolutionxnl
Drives: F30
Originally Posted by maupurr View Post
Hello everyone,
Thx!, I have the same issue on my n13 (320i Ed) and just ordered the parts
      07-03-2020, 02:11 AM   #3
nikolajaren
Drives: BMW 120D 2017
Oh damn this is a nice hack
      08-25-2020, 12:45 AM   #4
Plumbie87
Drives: Bmw f20
Hi Maupurr, how did this hack hold up? Was it a permanent fix?
Thanks.
      11-15-2020, 07:30 AM   #5
mrducati
Drives: 118d 2012, 116i 2013
Wow! I’ll Try this tomorrow!
      01-20-2021, 06:57 AM   #6
Masum2004
Drives: 2013 F20 116i
Did this work for you?
BMW F20 - Dec 2013 - N13 - NBT | Road Top CarPlay/MMI | iPhone 11 Pro | Aftermarket Rear Camera with OEM PDC | London, UK
      08-28-2023, 02:45 AM   #7
Dikkens
Drives: BMW F20
Would love a follow up on this from OP
      08-30-2023, 05:22 PM   #8
maupurr
Hungary
Actually I still have the car. The fiberglass wrap is holding up great since then. No issue whatsoever.
      03-11-2024, 05:44 AM   #9
chris.sck
Drives: BMW 116I 2015 N13
I've installed this yesterday. It works like a charm!
Pretty easy to install, i've got some tips for you out there:
-Instead of fiddling around with the roll just roll the wrap it around the bar and keep revolving it from there. Otherwise u have to cut it perfectly which would suck if done incorrectly. Before the next step, check if the windshield feels firm enough to ur liking.
-Afterwards slide the metal zip tie under it and lock it in as shown on the picture. Make sure u have a proper tool to cut the zip tie because it sucks if u don't haha.
Overall this installation took me like 1hr because i did it in pitch black environment + I had to look for something to properly cut the zip tie. I reckon this will take 30 min maximum if done right.
Tags
f20, f30, heat, n13, n13b16, noise, rattle, shield
1addicts
