08-27-2019, 03:17 AM | #1 |
Rep 5
coding issue depo leds
Hey guys I'm a newbie here although been lurking for some time some great info on this forum.
Not sure if anyone else has had this issue? but I've fitted sum aftermarket led headlights from eurowagens with HIDS (yes I've had the beams adjusted correctly so not throwing light all over the road and these were not the cheap nasty ones) Eurowagens say that they said are plug and play but the leds are flickering on start up for 10 sec and flickering when indicating but the only happens in DRL mode. There is no flicking when the side lights or headlights are on. I have tried coding using Bimmercode so changed from bulb to led and turned off cold and warm monitoring in DRL mode but it has not worked. Car has remembered the settings but made no difference. Do I need to code anything else as I've changed the bulbs from original halogen to HID? Any help would be greatly appreciated BMW 125d 2014 |
09-06-2019, 12:43 PM | #2 |
Rep 5
Update:
I've managed to code out the flashing of the DRLs on starting the car by deactivating the warm and cold voltage monitoring to all bulbs using Bimmercode. But I cannot code out the flashing of the DRLwhen indicating unless I've missed something ....? Last edited by BEMUFF; 09-28-2019 at 01:57 PM.. |
09-28-2019, 02:50 PM | #4 |
Rep 1,343
Surely: https://f20.1addicts.com/forums/show....php?t=1567838. There's a search functionality available in the menu right above.
