adaptive xenon headlight function
07-11-2019, 11:41 AM | #1 |
Rep 233
i cant really find any info on this. and im sure its normal operation but figured i would ask. my 335 has the xenon headlights and uses the far outer xenon bulb for hi and low. im assuming this is normal. but what would the inner headlight bulb be used for other than daytime running lights. if i change these out with led or another xenon bulb is there a way i can code the dme to use this as a normal function also?
07-11-2019, 12:03 PM | #2 |
Rep 73
I know they can be coded to operate as hi-beams/ flash-to-pass lights. There's a setting in the FRM to use either the outer xenons or the inner halogens as hi-beams/ flash-to-pass.
07-11-2019, 12:06 PM | #3 |
Rep 233
07-11-2019, 12:48 PM | #4 |
Rep 233
I know it's hard to tell because it isn't dark outside but is there any reason why my driver side bulb in significantly brighter than the passenger side. One picture is with driver wide covered up. The brighter one is with driver side showing
07-12-2019, 12:38 PM | #6 |
Rep 1,245
Brighter because aim is off or one bulb was replaced and the other wasnt.
The inner bulb on adaptive lights is used as a cornering light, turn the wheel while pointing against a wall and you will see the light on the side you are turning illuminate that direction.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
e90yyc2426.50 |
07-12-2019, 12:42 PM | #7 | |
Rep 233
07-12-2019, 12:43 PM | #8 |
Rep 233
Bulb is brighter. I re adjusted my headlights because I wanted them slightly higher they were a little low. But the driver side itself is way brighter. I have them sitting even. I just ordered 2 new bulbs with a 600k brightness. Hopefully new bulbs fixes the issue. If not may be a ground problem
07-12-2019, 12:57 PM | #9 |
Rep 1,245
Adaptive headlights should always have that function unless its been coded out.
What year is the car?
07-12-2019, 12:57 PM | #10 | |
2682
Rep 6,314
I personally just ordered cheapo Amazon 6000k to compare brightness and tint since I like a whiter glow than yellow ish. If I lose to much output I won't keep them As for your cornering lights try again at night with headlights to auto and put your indicator. It should turn on to. Also when you go to reverse, both cornering inner lights should light up when headlights are on. If they still don't light up then perhaps they were coded out or bulb is dead. But I think you would get a warning... not 100% sure tho. |
07-12-2019, 01:00 PM | #11 | ||
Rep 233
07-12-2019, 01:01 PM | #12 |
Rep 233
2008. And no they don't turn on in reverse or turning. My headlights are always set to auto. I never turn them otherwise. They only time they come on is if I use the flash to pass. Or daytime running light which I have daytime lights turned off
07-12-2019, 01:07 PM | #13 |
Rep 1,245
Oh, so they do come on then? Its just been coded for flash to pass.
07-12-2019, 01:09 PM | #14 | |
Rep 233
07-12-2019, 01:09 PM | #15 | |
Art Collector
2427
Rep 3,450
While all E90 xenons are self-leveling, not all are adaptive. If you don't have adaptive headlights (that turn), then those inner bulbs do nothing other than flash-to-pass or DRL at reduced brightness. As for the difference in brightness, as TypeDreezy mentioned, it's probably an issue of one bulb having been replaced. That's most likely. But! On my car, I had a brightness imbalance on my actual xenons. Replaced the bulbs; problem was still there. Turned out there was "fogging" on the inside of my headlight/projector lens, probably caused by moisture or other contamination after the dealership didn't full attach the backing cover (noobs). Worth a look, but probably just mismatched (age) bulbs. You'd likely notice anything that would physically diminish light output from your halogens.
When I'm dead, just throw me in the trash.
type-dRew641.00 |
07-12-2019, 01:12 PM | #16 | ||
Rep 233
07-12-2019, 01:15 PM | #17 |
Rep 1,245
The projector itself has a common issue of getting a fog/haze on the back of it diminishing light thrown, very common with our lights. Not something you can 'seal' out. But it definitely cant be made worse from a bum light seal.
07-12-2019, 01:17 PM | #19 |
Rep 233
Is there a way to tell just by looking at it if it's bad. I know I'll find out for sure when my new lights come in. But like if I pull the bulb out and look in there is it noticeable
07-12-2019, 01:18 PM | #20 | |
Rep 1,245
07-12-2019, 01:21 PM | #21 | ||
Rep 233
Check it out |
07-12-2019, 02:15 PM | #22 |
Art Collector
2427
Rep 3,450
Worth checking for sure, but the fogging referred to affects the projector lens specifically. So if your only issue is the inner halogens, that thread likely won't apply. Interested read nonetheless!
