06-15-2019, 02:34 PM | #1 |
Rep 255
Drives: F36 430d GC, XKR, Clio 172
high mileage adaptive dampers. When are they breaking?
I'm looking at buying an F31 330d with between 80-100k miles already on it with adaptive dampers. I'll be adding another 100k miles before I would look to re sell it.
Now there are some higher mileage F31 cars knocking around, how do the adaptive dampers seem to be holding up? And when they do inevitably pop and need replacing, whats the replacement part cost these days? (I get labour free at work which is fortunate) I've just had the dampers on my current E91 330d SE replaced (again) and Sachs parts all round inc new top mounts cost me about £290. I can imaging that wouldn't even buy a single adaptive damper! Thanks in advance |
06-16-2019, 02:21 AM | #2 | |
E36fiend
286
Rep 637
Drives: 2014 435i xDrive
06-16-2019, 05:45 PM | #3 |
5942
Rep 10,314
At 100K miles, the adaptive shocks are very close to the end of their useful life. If the springs are still original, I suggest to replace springs as well.
06-16-2019, 09:58 PM | #4 |
Rep 262
Drives: 2013 BMW 335i M-Sport
I'm at 100k right now and have no leaks or signs of failure. That said they do not feel at 100%. At $2,000 to replace just the dampers I'm looking into coilover options when the time comes to replace these puppies.
06-17-2019, 02:53 PM | #5 | |
5942
Rep 10,314
KW Street Comfort coilovers will be approx. $2K USD with installation + potential 4 wheel alignment depending on how much the vehicle has been lowered. |
06-18-2019, 05:11 AM | #6 |
Rep 255
£1554 inc VAT trade price for all 4
£1829 inc VAT retail price Thats direct from BMW in the UK I've done some googling for the B4 Damptronic direct replacements but can't seem to find anywhere that sells them? Are they actually available in the UK? |
06-19-2019, 06:52 AM | #7 |
Rep 627
I need one Adaptive drivers side front for my 330d Saloon if anyone changes theirs and wants to sell.
Think I've damaged it after hitting a pothole as it's abit noisy over bumps. |
07-04-2019, 08:45 AM | #8 | |
BMW CCA Member
491
Rep 808
Farkle did some pretty extensive research on the M Adaptive Suspension shocks, they are incredibly robust. |
07-16-2019, 09:48 PM | #9 | |
Rep 262
07-17-2019, 07:24 AM | #10 |
Rep 6
I'm at 110k miles on adaptive dampers and thinking of a suspension refresh. The car doesn't handle like it used to and there is an increase in road noise too.
Any advice on which linkages I should replace to tighten the handling and quieten the noise? Looking at RealOEM.com I see two linkages: "wishbone" and "tension strut with hydraulic mount". Do these both tend to wear out? Can just the bushings be replaced or do I need the whole assembly? Grateful for any advice! |
07-17-2019, 10:56 AM | #11 |
4041
Rep 3,548
Both of the rubber bushings and ball joints on those two control arms wear out. 110k is A LOT for the bushings. It's usually easier to just replace the whole assembly (bushing, arm, and ball joint) since they're sold as a complete assembly, and you don't need a press to take out the old bushing and install a new one. At 110k there's not really any point to only doing just one of the components. The tension strut should make the most difference with regards to feel.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
07-18-2019, 03:18 AM | #12 |
Rep 6
Thanks FaRKle! I'll take your advice on those control arms.
I'm already planning to replace the dampers (with Bilstein B4 damptronic rather than B6 because I like a soft ride on the highway) and I'm happy with my ride height, so I wasn't going to renew the springs. What about the "top hat" mountings. Do they wear out? |
07-18-2019, 01:03 PM | #13 |
4041
Rep 3,548
There's a bearing that the spring sits against to prevent bind on the top mount that can wear out. I don't think you can get that part separately, so it's worth it getting new top mount assemblies.
10-07-2019, 11:11 AM | #14 |
Rep 132
Hi jedi-knight83
You've probably sorted out your B4 Damptronic shocks now, but the cheapest place I've found in the UK are Balance Motorsport: Rears (£265): https://balancemotorsport.co.uk/cata...t/?q=20-238933 BTW these used to be £230 inc VAT so the price does fluctuate. Fronts are here: Left (£355) https://balancemotorsport.co.uk/cata...t/?q=23-238916 Right (£355): https://balancemotorsport.co.uk/cata...t/?q=23-238923 I'd be very interested to hear your review on these. I am in the process of replacing my standard pre-LCI shocks with LCI used ones with 14k on them (got a set of 4 for a very good price). Previous owner had lowering springs on mine and they are shot already at 25k miles. |
