06-10-2019, 03:48 PM | #1 |
220
Rep 541
Front Shocks - sdrive vs xdrive
What are the differences between the sdrive and xdrive front shocks, apart from the xdrive having accelerometer brackets?
I have heard the they are different diameters and so the sdrive ones would not fit the xdrive mounting clamp as they are bigger? |
06-10-2019, 05:07 PM | #2 |
4041
Rep 3,548
The tube diameters are the same. The difference are the end link mounting points. sDrive struts use the same strut left/right vs xDrive (and sDrive with EDC) has left/right specific struts.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 07-23-2019 at 10:45 AM.. |
06-10-2019, 08:33 PM | #3 | |
1153
Rep 1,523
The very early KW kits on the 2wd had the long bottom and later newer kits (2wd or xdrive) all switched to the smaller overhang. Ohlins also have the big overhang, so their kits wont fit xdrive. Orange circle shows 2wd strut and yellow circle shows xdrive strut. |
cfm56d7b5942.00 |
06-10-2019, 10:36 PM | #4 |
4041
Rep 3,548
Good catch.
06-11-2019, 06:50 AM | #5 |
220
Rep 541
OK. Thanks for the info.
So I have a chance to buy some barely set of B6 Damptronic Shocks for my 335d xdrive. I can get brackets to hold the accelerometers. Are you saying that there will be a clash with the drive shaft due to the overhang on B6 or not? Here is a picture. |
06-11-2019, 07:34 PM | #6 | ||
994
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
06-11-2019, 07:44 PM | #7 | |
Rep 141
Here is a picture of my B6 Damptronic for xDrive. Looks like they mount into the the knuckles differently.
2014 328i xDrive M-Sport EBII--M-Performance BBK/LSD/Aero--AA Signature Exhaust--Bilstein B6 DampTronic + Eibach Springs + H&R Swaybars + Millway Street Camber Plates + M3 Bump Stops + Dinan Shockware--Apex ARC-8 18x9.5et35+12mm Front Spacers w/Kumho Ecsta V730 275/35--FL-5/EC-7 18x8.5et35 w/Pilot Alpin PA4/Hakkapeliitta 10 Studded 245/45--BavSound Stage 1+Ghost Subs
Last edited by thisismikeyb; 06-11-2019 at 08:23 PM.. Reason: Double Quoted DriveS |
06-11-2019, 07:48 PM | #8 |
1153
Rep 1,523
You can clearly see there is more bottom overhang on the 2wd strut.
06-12-2019, 06:09 AM | #9 |
220
Rep 541
