06-04-2019, 02:20 PM | #1 |
Rep 189
MPE axleback or Dinan Midpipe?
Need help deciding between buying a used MPE axleback or keeping the stock muffler and just installing a Dinan Midpipe on my 2016 340i.
I need something a little louder than stock, but still want it to be quiet and comfortable when driving on long road trips. The MPE for the B58 does not have the valves for going quiet in comfort mode, and would probably run around $800-900 used, and the Dinan mid pipe would retain the stock muffler and valves and runs $500 brand new shipped to my front door. I've watched countless videos of both on youtube, but never heard either in person. Is one option significantly louder than the other? If I just do a mid pipe will I even notice a difference with the stock muffler? Curious to hear different people's opinions/perspectives. |
06-04-2019, 03:07 PM | #2 |
Rep 233
Stuck in the same boat as you - I want a bit more exhaust noise but I can't seem to convince myself to go with a downpipe just yet, even though I know that would accomplish the more noise without excessive noise situation. (I have 1.5 years left on CPO, and even though I'm running BM3, I just feel like installing a DP is going to put me further out of warranty than I'm comfortable with)
I'm looking at pulling the trigger on the mid-pipe instead of MPE given that it I'll still have a valve and can get just a bit more noise, I'll be following here to see what other people say to help drive one way or another. |
06-04-2019, 04:16 PM | #3 | |
Rep 189
Yeah, I know what you mean about the warranty. I know different people have different schools of thought, I've always felt comfortable with cat backs and axle backs as long as the cats and nothing north of the cats were touched. For the tune, do these cars have key stroke logs or would they have no way of knowing that you tuned it if you reverted it back to stock?
I'm leaning towards the mid pipe with stock muffler mainly because of the cost and being able to retain the valves. My only hesitation is not knowing if it makes a noticeable difference in volume/sound. If it's just as loud as the MPE, than it's a no brainier for me to do mid pipes if there's no drone. Quote:
06-04-2019, 05:05 PM | #4 |
Rep 1,456
I would get the mid pipe. MPE alone with stock down pipe and mid pipe only gives you like a 15% increase in noise. I have one, but I installed it at the same time when I did my DP so its loud and poppy now.
06-04-2019, 07:25 PM | #5 | |
Rep 233
06-04-2019, 07:37 PM | #6 |
Rep 189
Thanks for that insight. Would you say that the mid pipe would give me more sound than the MPE or about the same so you're saying go with the cheaper option?
06-04-2019, 08:24 PM | #7 |
Rep 83
I have the DINAN mid-pipe with stock (for now) downpipe and muffler. I like the sound with only the mid-pipe. A few extra burbles, a little louder when I get on the gas, but otherwise it is as quite as stock. For me it is just enough. I'm adding a high flow cat to support my MHD Stage 2 flash tune.
2018 440i Gran Coupe (F36), Glacier Silver/Black Dakota, M Performance and Track Handling Package, MHD Stage 2 and xHP Stage 3 flash tunes, Dinan Shockware and mid-pipe, HJS high-flow cat, AP Intake, RW Carbon duck bill spoiler and rear diffuser
06-04-2019, 08:28 PM | #8 | |
Rep 1,456
YouTube videos I've watch. If you plan on going with the MPE you can always delete 1 resonator or both to make it sound more aggressive if you plan on keeping the stock down-pipe. |
PURE340i104.00 |
06-04-2019, 08:34 PM | #9 | |
Rep 640
Drives: 2008 M3 (E93)
IMO, all the exhaust setups we're like 1k+ and I couldn't justify spending that just for some sound improvement. If you plan to go FBO with downpipe, tune and everything it may be worth it to spend the extra $$ and get a full exhaust. Hope this helps |
06-05-2019, 01:46 AM | #10 |
24384
Rep 191,215
REMUS axle back would be the best option in my opinion for a sound upgrade thats still mild and no drone.
But between the 2 options you listed, i would go with Dinan midpipe
06-05-2019, 05:35 AM | #11 |
Rep 189
Thanks for all replies everyone, this is really helpful.
For this car I don't have any big plans to mod, not looking to get more power or tune it. I just want a little more sound but I don't want it to be obnoxiously loud from inside the cabin (it needs to be quiet when I'm casually driving at highway speeds). Sounds like an axle back would get me something similar but would just be double the price so a mid-pipe would be the better route. My only hesitation was that I wasn't sure if it was a noticeable sound difference to make it worth the $500, but it sounds like it is. |
06-11-2019, 09:05 PM | #12 | |
24384
Rep 191,215
06-12-2019, 03:48 PM | #13 | ||
Rep 1,103
06-12-2019, 05:14 PM | #14 | |
Rep 189
Not familiar with the AA, and don't see too many posts here about them. What type of exhaust note are these similar to? Is it more similar to the MPE (crackle pop, higher pitched) or more like the Remus (deeper tone)? I assume no issues with drone and these are valved? I already ordered the mid pipes, can are these two parts compatible to each other without custom work/welding? |
06-12-2019, 11:23 PM | #15 | |
24384
Rep 191,215
And yes i said close not the same price. they should fit together using the clamp provided but im not too sure. You might need to wield
06-22-2019, 04:32 PM | #16 |
Rep 132
Drives: OG M2
Dinan midpipe, otherwise stock exhaust:
Zero drone whether the valves are open or closed and a good amount more volume/tone than the stock exhaust.
M2 - TC Kline DA Coilovers - Apex SM-10s - 265 RS-4s - Dinan Intake - BM3 - CSF Intercooler - VRSF CP
Previous: 6th Gen Camaro SS 1LE | 2020 JLUR Wrangler | F30 340i | B7 Audi A4 APR Tuned | E46 330ci Instagram @track.n.trail |
06-23-2019, 08:40 AM | #17 |
Rep 189
Great video! Just installed mine a few weekends ago, and I'm happy with it also. No drone, and sounds way louder from the outside of the car. On the inside you can barely hear it under a normal acceleration or just cruising around town, but with WOT you can hear it (like in this video).
06-26-2019, 12:18 AM | #18 |
Rep 387
I dont know how to explain this question. But with the mid pipe. Can you feel the sound? Not literally feel it but figuratively. Wondering if you can "feel" you have power especially while normal cruising without it actually being obnoxious from the outside.
After reading what I wrote it sounds stupid to understand ahah |
06-26-2019, 05:27 AM | #19 | |
Rep 189
pimp4cheddar520.50 |
06-27-2019, 07:53 PM | #21 |
Rep 189
No noticeable power gains with a mid pipe. I doubt you can feel any difference with a cat back either, at least I've never have on any other car I've ever had. You may if you pair it with a tune though, but most power gains for an exhaust come from upgrading a down-pipe on a turbo engine or headers on a naturally aspirated/supercharged engine, but if you are doing that, you should be getting a tune anyways because it's a much larger back pressure difference.
06-28-2019, 12:52 AM | #22 | |
24384
Rep 191,215
