Bimmerpost
4 Series
Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Remote Start
      06-04-2019, 10:38 AM   #1
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
Remote Start
Has anyone gotten this to work? Mine never works via the app.
      06-05-2019, 11:23 AM   #2
lewiad
Drives: 2019 330i
Mine works without any problems.
You might have to go into climate settings and enable remote start. It should be in climate settings then an option like ventilation settings.
mzdial116.00
      06-07-2019, 11:48 AM   #3
Donia330i
Donia330i's Avatar
Drives: 19 330i BSM
signed in and out of the app a few times. finally got it working!
      06-23-2019, 07:48 AM   #4
transcendid
transcendid's Avatar
45
Drives: 2020 m340i RWD
2020 BMW M340i  [0.00]
Question about remote start from the app- can it be used to set a specific interior temperature? Or does it just turn on the car with whatever temperature and AC settings you had set when the car was last turned off.
      06-23-2019, 04:54 PM   #5
dpod25
Drives: 2019 330i xDrive
You can also remote start the car by pressing the BMW logo (lock button) on the key fob 3 times.
It's the latter. It will only turn on the car and run the climate system based on the setting when it was last turned off.
      06-23-2019, 07:31 PM   #6
transcendid
45
Thanks! Bummer that you can't change settings from app.
dpod25102.00
      06-24-2019, 06:28 PM   #7
Antkn33
Drives: 2020 M340i xdrive
It only works when at home for me. Whenever I try it away from home it fails.
      10-06-2019, 05:46 PM   #8
SCardamon
SCardamon's Avatar
Drives: 2019 330i
Thanks for the tip on three button press.
Sending mine into the dealer for the repeated failure to remote start - Connected features are so unreliable, ridiculously so
g20
