04-22-2019, 03:06 PM | #1 |
Rep 1,133
Brake pad wear sensor
Quick question. If the existing pad wear sensor didn't go off but I want to change the brakes because the rotor is warped, can I use the existing sensor?
04-22-2019, 04:35 PM | #3 |
Modder of everything I own
147
Rep 491
If you can get it out without damaging the end.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
04-23-2019, 09:22 AM | #5 |
147
Rep 491
no problem! I damaged the end a bit when I removed mine, and it wouldn't stay seated properly so I had to order a replacement.
