04-15-2019, 12:05 AM | #1 |
Rep 8
Steering wheel locks up on lowered Dinan Springs and Stock shocks*
Hey guys, a few months back I lowered my car on Dinan lowering springs and installed them on stock shocks with the bump stops. Everything looks and feels great driving it normally. It's only when I try driving it hard and making sharp turns where I see some issues. When I try to make a sharp right turn, if I turn my steering wheel 180 degrees it kinda locks up like a stiff joint in your arm or leg and I would have to push a bit harder for it to release. This only occurs when I turn right at speeds more than 30km/h. I'm assuming there's something wrong with the left side of the car since the left dips down when I turn right. |
04-15-2019, 07:05 AM | #2 | |
Rep 117
Jaysongz920.00 |
04-16-2019, 07:35 AM | #3 |
Rep 255
I'd guess this has nothing to do with the Dinan springs themselves, but instead maybe something from the installation or even a power steering issue of some sort.
Jaysongz920.00 |
04-16-2019, 07:43 AM | #4 | ||||
Rep 8
04-17-2019, 02:08 PM | #5 |
Cheapskate
4464
Rep 4,995
You may have installed a sway bar end link incorrectly and it's binding. Or your alignment is off and you need to recenter your steering rack.
Jaysongz920.00 |
04-18-2019, 01:07 PM | #6 |
Rep 8
So I went under the car today, the charge pipe does not seem to be in the way of anything. So I'm assuming that it must have to do with the install itself.
