03-19-2019, 11:13 PM | #1 |
Rep 32
Yet another "My first oil change"....or EZ Oil drain on 328D x-drive
Two weeks ago, I bought a 2014 328D X-drive with 67,000km.
The car was well maintained and super clean. I love the car and wanted to get the oil changed. I picked up everything I needed: Mahle OX404D Oil Filter 6L Penzoil Euro L 5w30 (LL-04) (5.2L needed) EZ Oil Drain EZ-109 M12x1.5 27mm Oil filter socket 17mm socket and ratchet Funnel Oil pan Blackstone sample container On my other vehicles I typically use Fumoto oil drains, but after doing some reading online, I decided to to try an EZ Oil drain because it looked to have a much shallower profile. I pulled the car up on ramps, removed the cover under the hood. Then I opened the oil cap, removed the drain plug and filter. Once the the oil was all drained, I packed a sample for Blackstone and installed the new filter. I climbed underneath the car to look at the drain hole, the EZ-109 looked to be a close fit...but a little bit of the undercarriage protection was just a little to close to allow the drain to be turned into place. I had read others had filed the opening, but decided to bend the opening with pair of channel locks. It need only a slight bend to allow the EZ oil drain to spin completely. The low profile of the EZ-109 keeps it completely tucked away. I refilled with 5.2L, checked the oil level and it is good for another 10,000km |
01-15-2020, 07:45 PM | #3 |
1001
Rep 2,217
He stated, "EZ Oil Drain EZ-109 M12x1.5."
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
