03-07-2019, 04:43 PM | #1 |
Rep 33
Cons of setting KW SC Coilovers past max height?
I already have my front set to "Maximum A" distance and don't like how low it is.
There's about 1" of threading left. What would be some draw backs or raising the front another 3/4", not to exceed the threads (like i did last time and destroyed the perches)? Last edited by HandyRandy; 03-07-2019 at 04:55 PM.. |
03-08-2019, 11:20 AM | #2 |
5942
Rep 10,314
It will be prudent to call KW and get the answer from the experts. I called KW in the past and the person answering the phone was very helpful. I wanted to maintain close to OEM suspension height with KW Street Comfort coilovers.
03-08-2019, 06:17 PM | #3 |
Rep 33
03-08-2019, 06:59 PM | #4 |
994
Rep 1,934
Aren't where the threads end max height? How are you getting the collars past that?
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
03-08-2019, 09:13 PM | #5 |
Rep 33
03-09-2019, 02:50 AM | #7 |
994
Rep 1,934
The kw max height for those is where the threads end to my understanding. So you can't go past thay. It's not a recommendstion really, it's just a spec. The SC can go, at their highest, 10mm lower than base suspension which is the same as xdrive. All the other KWs start 30mm lower, at their highest.
03-09-2019, 08:01 AM | #8 | |
Rep 33
03-16-2019, 08:17 AM | #9 | |
Rep 33
When it comes to suspension height, go by "measurement B" (wheel center to stock fender). In my case (KW SC 1802000R) the minimum distance is 13.4" with an unlisted max of 14.6". Height adjustment is physical limited by the threads on the strut. Any additional height can be obtained with spring spacers,with no cons: - 15 mm - 30 mm - 50 mm In my case, I have a measurement B at rear of 13". I want about 14" at the front (at 13.75 at highest setting)....dont like the leaning foward look you get if you try to make front and rear wheel gaps the same (believe its called raking). In my case, I would get a 15 mm spacer. |
rcaso26331.00 |
