02-11-2019, 07:47 PM | #1 |
Rep 117
Rear Axle Differential Lock Error
Getting this error in my 2017 M2 (manual) whenever I get stuck in snow (happened twice these past 2 days on our steep driveway just moving the car around).
I don't drive the car during winter weather, thus I leave the summer tires on and bone headed-ly got it stuck on our driveway for a brief period. While wrestling with getting it unstuck I got this error message, I was in traction mode and slipping the clutch and giving it a little extra throttle- nothing too crazy, never really even went over 3.5-4K RPM if I recall. Do you guys think this is cause for concern? Or were my attempts at getting out of the snow in poor taste and causing undue stress/heatsoak on the drivetrain? Debating whether to make an appointment with the dealership or just call it a mulligan and keep an eye on the car's diff this summer. Thanks for your help.
2017 M2 6MT | 2018 C43 AMG
02-12-2019, 09:18 AM | #2 |
10933
Rep 4,551
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh....php?t=1382873 https://f80.bimmerpost.com/forums/sh....php?t=1130911 Could be anything from a simple sensor failure due to low voltage from not driving it enough in the winter or you may have overheated the diff and damaged something while you were trying to get it up your driveway. You won't know till you take it in and get the fault code read and the car inspected. My advice would be to get it sorted ASAP as new parts sometimes take weeks to deliver from overseas. |
NYC Bimmer259.50 |
02-12-2019, 11:21 AM | #3 | |
Rep 117
Anthony1s755.50 |
02-12-2019, 10:53 PM | #4 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
Something not right with your car, because I've been driving mine through snow both last winter and this winter (using snow tires) and have never seen this error.
I've even done some repetitive circular patterns in snow-covered parking lots...
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
///M Houbi1655.00 |
02-13-2019, 05:16 AM | #5 |
Rep 117
Ha, yeah I figured that what I was doing was no worse (or better) than just doing ~5 minutes of donuts in the snow.
03-01-2019, 08:53 PM | #6 |
Rep 117
Well as an update to the issue, dealership took a look at everything during a routine oil change appt. and their equipment recommended only a software update. The SA stated that there was no further action required on their part, nor were they able to replicate the fault.
Overall very unfruitful, but I haven't had the issue reoccur even for me in quite some time now... And I tried to launch the hell out of the car in attempt to replicate the error as well.
tux2005234.00 |
03-03-2019, 02:06 PM | #7 | |
756
Rep 2,149
Of course we want to tell the dealership ASAP to prevent it from causing a bigger issue, and make sure it's taken care of before warranty expires, but sometimes all that can be done it to monitor the situation and get more data to diagnose with if it happens again. But glad it hasn't come back, even under the additional launch stress you gave it, and I hope it stays that way. |
03-17-2019, 11:11 AM | #8 | |
Rep 15
03-18-2019, 08:14 AM | #9 | |
Rep 117
More importantly I was never rocking the car as I normally would when stuck in snow, as I was not stuck- I just lost traction on a slope for a few minutes. Big difference between rocking a car (and inducing drivetrain shock and gear backlash) and slightly slipping a clutch dude. I'd be concerned if a locking diff had such a low level of usability as I've lived in the upper midwest for over a decade and owned several sports cars with mechanical LSD/Haldex/E-Diff/etc. which never exhibited this type of behavior...
AndrewC198910932.50 tux2005234.00 |
06-22-2019, 01:31 PM | #10 |
Rep 350
I got this message yesterday along with several others (chassis stabilization, TPMS, collision warning systems) and my DCT would only engage reverse, neutral and 2nd. I ended up needing to get it towed to the dealership and they won't have a chance to really look at it until Monday now.
I was at the race track with it, I'd got 2x 20 mins sessions in, then had lunch and upon going out to fire up for the afternoon the messages started firing off. It was quite a disappointing turn of events, I'd been making good progress in the morning. So you just had a software update and nothing else? It sounds like my issues were almost certainly more widespread than yours, I hope they can sort them out properly because I don't want the same thing happening at my next track day which is 5 hours away! |
06-23-2019, 06:54 PM | #11 | |
Rep 117
For what it's worth, I track my M2 as well and I have never had this issue at the track, so it sounds like yours might be a different root cause/issue altogether. Mine is a 6MT, but yours sounds a lot more like a transmission issue rather than a pure diff issue. Best of luck and let us know what the news is. My first track day I boiled my fluid and got crazy chunking on the crap continentals within my first two sessions hah, 2.5 hours drive one way completely wasted because I couldn't even run again as I had such bad vibrations.
07-01-2019, 08:04 AM | #12 |
Rep 350
Yes, it seems like my issue was different. There were issues on the 5V lines and they traced it to a faulty Valvetronic motor so they replaced that and the accelerator pedal module. That has cleared everything so I suppose the diff lock error was probably triggered by a fault somewhere else in the system rather than something with the actual diff. I don't think there was any software update for me, their notes don't include anything and I still have all my coding.
I think the transmission issue was probably also just a limp mode due to faulty readings. |
