01-31-2019, 07:09 AM | #1 |
409
Rep 585
Drives: 2018 M2
COLD...Clutch is slow
Anyone else experience a slow-to-engage clutch at 0F or below?
01-31-2019, 08:23 AM | #3 |
Da Baus
283
Rep 259
Ya its sticky for the first 15 mins
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
01-31-2019, 09:11 AM | #6 |
409
Rep 585
Drives: 2018 M2
Mine too! I actually thought the tires were slipping but I think it was the clutch because I didn't give it much throttle and I didn't skid to a stop at that location.
01-31-2019, 11:04 AM | #7 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Machinery doesn't work well in -28° temps, no matter how sophisticated and advanced it may be.
My stick shift felt like it was stuck in soft cement this morning in -3° temps.
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
detroitm22431.50 M3 Adjuster7909.00 |
01-31-2019, 12:14 PM | #8 |
444
Rep 468
Yep same here, everything is pretty clunky in those first 5-10mins on a cold morning. I just take it easy on the shifts and throttle engagement etc but once moving I try to shift up around 3-4k rpm (rather than short shift) to heat everything up efficiently.
Not sure if it's an M2 thing or normal for manual cars but yeah the thing is clunky as hell when it's super cold. |
01-31-2019, 01:28 PM | #9 | |
2432
Rep 2,526
01-31-2019, 01:52 PM | #10 |
Rep 38
All mine have been like that except for a pontiac lemans hatchback I had back in the day. It didn't have much of a clutch left though so that could possibly be why it wasn't stiff.
01-31-2019, 02:10 PM | #11 |
Space Force - 4 Star General
11468
Rep 3,264
Man I don't envy you mid-west guys. -30 degrees. Sticking clutches. F that. You all are bad asses!
QM287.00 M3 Adjuster7909.00 |
01-31-2019, 03:55 PM | #12 |
3360
Rep 1,823
Is the brake fluid reservoir and clutch reservoir shared on the M2? I was on my Mustang. But either way, think of clutch fluid in the same way you think of brake fluid. When it's cold it's like molasses. It does not want to flow. So clutch and brake performance is slower.
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
02-01-2019, 09:11 PM | #14 |
Moderator
29656
Rep 13,138
Don't forget the E46 M3 SMGII transmission clunkiness on cold mornings.
///M is art ↔ Artemis
02-02-2019, 08:25 AM | #15 |
Rep 312
When it got really cold (-20F), I heard and felt a really faint noise and very slight pulsation from the steering just after startup and when turning at low speed. I'm guessing that was the electric steering motor? Once the car warmed up it was gone.
02-02-2019, 10:40 AM | #16 |
5585
Rep 5,385
Fluid is very thick and viscous at those temps. Also, care should be taken until the gear oil is fully warm (at least 10-15 minutes of driving on a stone cold tranny, even more so in extreme cold) or else you risk munching a syncro, especially the 1-2 which is under a ton of torque under boost/full power.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
02-03-2019, 03:40 PM | #17 |
2316
Rep 4,341
Clutch material is like brake pads. The compounds have a certain amount of bite at certain temperatures. Cluthches are meant to hold up to a lot of heat and unlike your crossdrilled brakes and open wheels, there is no airflow. So it makes sense that the clutch would be less efficient at those temperatures. That is why you are supposed to drive the car easily until it comes up to temperature.
02-04-2019, 11:25 AM | #18 | |
409
Rep 585
Drives: 2018 M2
02-04-2019, 11:57 AM | #19 | ||
2316
Rep 4,341
02-04-2019, 12:03 PM | #20 | |||
409
Rep 585
Drives: 2018 M2
02-04-2019, 12:27 PM | #21 | ||||
2316
Rep 4,341
M2guru409.00 |
