01-24-2019, 07:25 AM | #1 |
Rep 718
Removing Rear Center Headrest?
Is there a trick to removing the rear center headrest? I can pull it all the way up, but it stops there. It's a bit of a distraction and I know I'll never have anyone in the rear center seat. Thanks.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!) |
04-09-2019, 12:38 PM | #5 |
Rep 1,480
Drives: 2022 M440xi GC
I would like to know too, my x1 just pulled right out, this one wants nothing to do with that.
04-10-2019, 05:52 PM | #7 |
1910
Rep 5,105
Not removable, same with my previous 2 X3's
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
04-10-2019, 11:58 PM | #8 |
Rep 1
Follow the video on how to pop-out the plastic tab. Once the tab is off you will need to remove the gray clip that is holds the headrest in. When the gray clip is removed you will be able to slide the headrest out.
This was the first thing I did after I parked it in my garage. |
04-14-2019, 12:50 AM | #9 |
Rep 228
Yes, it's like a C clip. Get a small flat blade screwdriver. You should see the end of it if you're kneeling on the rear seat facing towards the rear. Get behind it and pull towards yourself and toward the back of the car. With little force, it will pop. I believe the pic above is from the cargo area and you're seeing the loop part of the C clip.
04-14-2019, 09:32 AM | #10 | |
1910
Rep 5,105
04-22-2019, 09:52 AM | #11 |
Rep 46
Thank you for the info about the gray clip. Finally got a chance to access my daughter's X2 and spent about two minutes getting this done.
Problem solved and rearward vision improved. Thanks again! |
