12-15-2018, 06:09 AM | #1 |
Rep 602
Coding the G05 - has anyone been able to do it yet?
Has anyone figured out how to get ANY coding done with the G05 yet? I have a list of things I would like to code in:
CarPlay is not activated since I am in Germany Remote Start Increased DRL brightness Increased Laser Light brightness and anti-dazzle Increased seat heating/cooling change some things in my display Im sure there will be more... Also, what are other options that you all want to get coded in? |
01-06-2019, 09:27 AM | #2 | |
Rep 84
Anyone has any updates? I tried on Carly and other than exhaust flap control and few minor troubleshooting features, coding does not work. |
01-06-2019, 11:44 AM | #3 |
866
Rep 5,452
Only way is Esys with latest daten files and latest Launcher Pro v3.0 and still pretty limited, a few ECU's can be coded like setting auto start stop.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
01-06-2019, 01:39 PM | #4 |
Rep 978
I've reached out to the person I work with to get coding done. So far, limited access to control modules - allowing only a few edits to the software's settings:
ASS - set to last memory setting Enable close trunk from interior button AND key Disable seatbelt chimes |
01-06-2019, 01:45 PM | #5 |
Rep 293
So Carly does work with the exhaust flap? If so could you do me a huge favor? Could you open the flap, then unplug the servo motor underneath and see if the flap remains open?? This would answer a huge burning question that I cant see to get answered!
01-06-2019, 02:49 PM | #8 | |
Rep 84
01-06-2019, 04:59 PM | #10 |
Rep 84
01-06-2019, 05:44 PM | #11 |
Rep 293
BMW_Cyprus50.00 |
01-06-2019, 05:57 PM | #13 | |
Rep 84
As asked above, I will try to open it and disconnect the cable and see if it stays. |
01-06-2019, 07:03 PM | #14 |
Rep 293
Gotcha, thought coding was more of a general term. I appreciate you experimenting for me!
01-06-2019, 08:59 PM | #15 |
866
Rep 5,452
Carly does not work at all, emailed them and they said try previous model to connect which doesn't work, G05 is in the app, but it only finds one ECU in the car it recognizes and then fails to read it, so Carly is 100% no go at this point.
01-06-2019, 09:11 PM | #16 |
12972
Rep 18,717
Anyone local to me in Los Angeles, I can try to code it via E-Sys.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
01-09-2019, 05:45 PM | #18 | |
Rep 84
I may put a bag over the connector and drive around a few days and report again. |
01-09-2019, 05:49 PM | #19 |
Rep 84
Carly does not do ASS at the moment, but Bimmercode responded by email saying that they do allow it now, as they said nothing else is programmable now.
If you are fan of sport mode, just switch to sport and ass automatically gets into off position. |
01-09-2019, 06:06 PM | #20 | |
Rep 36
01-09-2019, 08:46 PM | #21 | |
Rep 293
Thanks! |
01-09-2019, 09:21 PM | #22 | ||
Rep 84
Tags |
2019, bluetooth, carplay, coding, display, g05, laser, obd, obdii, remote |
