M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Easiest Way to Keep Exhaust Valve Open?
      11-23-2018, 02:26 PM   #1
bdogk
300
Drives: M2CS,M4GTS,'21-X3
Can aonyone point me to the simplest way of keeping the exhaust valve open on my M2C.
Is there a specific fuse I can remove or the proper procedure of pulling the valve harness.
I also read in another thread somewhere a while back there's a harness plug you need to purchase if you pull the harness.
      11-23-2018, 08:06 PM   #2
SUB-ZERO
SUB-ZERO's Avatar
294
Drives: 2018 M2 + Spur, DB11, F12, X5
BimmerCode/BimmerLink
      11-23-2018, 08:33 PM   #3
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
Saw this in my suggestions..
M2Cnme33.00
      11-23-2018, 09:08 PM   #4
nomoracin
Drives: Porsche GTS 4.0
+1
      11-23-2018, 09:34 PM   #5
CJ41BIG
Romania
64
Drives: M2C
The easiest way is to remove fuses 146 and 147 (5A fuses) after you have stopped the car in Sport + mode. Don"t bother....... the result of leaving open flaps equal to 0 ...in Efficient and Sport mode the exhaust will be silent....our enemy is OPF.
My conclusion: slip on aftermarket exhaust (to be legal). Something like Remus, Lightweight and soon Akrapovic.
Now I see...you are from Canada and you dont,t have OPF installed on the car.)))
I will send you somme pictures with the steps to remouve that fuses
      11-26-2018, 12:52 PM   #6
bdogk
300
Yes, please do. You can also PM me if you prefer. Thanks.
      11-27-2018, 08:58 PM   #7
CJ41BIG
Romania
64
Drives: M2C
Step 1: stop de engine in sport+ mode (flaps will remain open)
cptobvious2531.50
      11-27-2018, 09:00 PM   #8
CJ41BIG
Romania
64
Drives: M2C
Step2: in right-front of trunk will find box fuses
cptobvious2531.50
      11-27-2018, 09:03 PM   #9
CJ41BIG
Romania
64
Drives: M2C
Step3: pull out these 2 fuses
Appreciate 3
      11-27-2018, 09:07 PM   #10
CJ41BIG
Romania
64
Drives: M2C
Step4: problem solved without any error lights in bord.
Appreciate 12
      01-01-2019, 07:38 PM   #11
CanadianDriver
Drives: P3D-
hjk did you try the fuse mod? how different was the sound afterwards?
      01-01-2019, 09:43 PM   #12
Cycle Pilot
Drives: 2019 M2C
I'm curious about this. I've heard another way is just disconnect the valve harnesses after stopping in Sport+.
      01-02-2019, 03:37 AM   #13
mlx.milano
Drives: BMW M2C
Is there any other side effect of removing these fuses? I mean, any loss of performance at low RPMs, or any broken system in the car? Anything?
      01-02-2019, 03:57 AM   #14
CJ41BIG
Romania
64
Drives: M2C
This way is ok too, but is more complicated because you need to protect conectors agains mud, water etc
      01-02-2019, 03:58 AM   #15
CJ41BIG
Romania
64
Drives: M2C
Nothing!
      01-02-2019, 04:54 AM   #16
Poochie
Poochie's Avatar
Drives: 2016 M2
Thanks for the DIY
I'm assuming one fuse is [COLOR="DarkRed"]left[/COLOR] and the other one is for the [COLOR="Green"]right[/COLOR] side valve actuator?
      01-02-2019, 05:11 AM   #17
CJ41BIG
Romania
64
Drives: M2C
Thanks for the DIY
Correct
Poochie9104.50
      01-02-2019, 06:39 AM   #18
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
Fuse 146 and 147 are there for three things:
- valve controllers (one each fuse)
- Park Assistant
- DC/DC Converter
Since the M2C has no Parking Assitant this will be no issue.
But honestly I'm not sure if it is a smart idea to bypass the DC/DC Converter. Probably not -> https://f80.bimmerpost.com/forums/sh....php?t=1260067
That's why I stick with BimmerLink for the time being. BimmerCode won't help you with the valves and BimmerLink is not permanent. You have to have your dongle in, connected and the app running for it to work.
Sooner or later I'll probably go with the Macht Schnell EVC:
Appreciate 3
Poochie9104.50
PHX102160.50
      01-02-2019, 08:21 AM   #19
Proctor750
426
Drives: E30 M3
Sorry if this was covered elsewhere on forum but - is there any way to force the car to remain in M1 or M2 mode? I have everything turned off and set to M2, it's slightly annoying to have to press it every time. I also notice if you rapidly press the button if you are impatient the screen goes completely blank.
Also - can the same be done for the button down low that tells you if you are approaching a vehicle too quickly? I have the bimmercode app if that helps...
Sorry for the side bar
Edit: I don't think you need to worry about the DC/DC converter as it's probably just for maintaining stable voltage to certain components during auto start/stop. Seeing as it is the most useless feature ever designed in a car I have it completely disabled anyway.
The DC/DC converter is a power stabilizer to maintain constant voltage at sensitive modules during the voltage drop of the car's auto start/stop.
      01-02-2019, 03:14 PM   #20
CJ41BIG
Romania
64
Drives: M2C
Basically everybody is interested in how the car sounds in efficient mode with the open valves.
For EU car I can give feedback... allmost 0.
For US car If somebody can give feedback it would be useful.
DKM224.50
      01-04-2019, 06:29 PM   #21
nomoracin
- Park Assistant
- DC/DC Converter
I'm so confused...I swear my valve stays open without the dongle plugged in and app running.
Am I crazy or is this a difference between the EU and US versions?
      01-04-2019, 09:53 PM   #22
bdogk
300
No, I have not tried the fuse mod. And after reading what these two fuses serve, I'm not so sure I want to attempt this.
I would rather remove the connectors and wrap them with something waterproof instead.
Can anyone share their proper procedure to do this?
m2
