BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > NBT EVO ECU flash failed
      11-12-2018, 03:06 AM   #1
hugo325
Drives: 118i (M sport) [F20-2018]
Hello,
I am writing this new post because I am doing a retrofit from HU_ENTRY to HU_NBT2 (NBT EVO).
I would like to completely reflash my HI_NBT2 because this one had the CP (component protection) active.
The first step I did was to start the job "HU_SPECIAL_NBTEVO_CLEAR_V850" with the tool "tool32".
comment : deletes Persistency on NBTevo V850
important: Reflash+Recoding needed afterwards as also logistic
When performing a SVT reading I now have this in the ECU "HU_NBT2":
The second step is to fully reflash the HU_NBT2.
For this I followed the procedure below:
1) Go go comfort mode (TAL-Calculating)
- read FA then save
- active FA
- read SVT Actual then save (SVT_tal_1)
- create an SVT target
Under KIS/SVT Target Calculation Strategy, i select "Complete Flash".
I Select I-step (shipm :
Do a KIS/SVT Target Calculation
Click on the button "HW-IDs from SVTactual"
Then save as SVT_sol_1
I have 2 warning :
WARN events:
"[] Warning 1680, no application data list available for ECUId:HU_NBT2_0x63, (Exception: error while switching to extended diagnostic session),
[] Warning 1680, no application data list available for ECUId:PIA_MASTER_0x63, (Exception: error while switching to extended diagnostic session)" [C382]
2) Go to expert mode (TAL-processing)
- Load TAL (SVT_tal_1)
- Load SVT Target (SVT_sol_1)
- select "read FA" button
- click the button "Read VIN", then select the "read VIN out of FA"
But unfortunately I have no line named "HU_NBT2"
Do you know why I can not flash this ECU?
Do I have to correct the warnings in the "KIS / SVT Target Calculation" step?
      06-11-2019, 01:18 PM   #2
kubax86
kubax86's Avatar
1790
Drives: M2
pm me!
can help
      12-27-2019, 03:36 AM   #3
aniskinruslan
Azerbaijan
Drives: F30
Originally Posted by kubax86 View Post
pm me!
can help
Could you please pm me? i need your help
      07-02-2020, 01:55 AM   #4
blisz
Drives: e46 3301
pm me!
can help
Hello Kubax86,
I've got the same problem.
Can you help me with that?
I've these two errors by TAL calculation
WARN events:
I hope you can help me,
Kind regards,
Tijs
      07-02-2020, 05:59 AM   #5
kubax86
kubax86's Avatar
1790
Drives: M2
Hello,
Sure write me PM.
Thanks
      07-22-2020, 02:23 PM   #6
f30og
f30og's Avatar
Drives: f30 328i
pm me!
can help
can you help me, having same issue
      07-23-2020, 12:54 PM   #7
kubax86
kubax86's Avatar
1790
Drives: M2
Hey,
Sure, message me your issue on PM
Thanks
      10-29-2020, 06:21 PM   #8
bestwick
Drives: 320D F30
Hey,
Thanks
Dear
I have the same failure trying to call TAL to flash, please help.
      01-04-2021, 02:16 PM   #9
jivakula
Bulgaria
Drives: F11 , F15
Hi there! I have the same issues with warning ECUId:PIA_MASTER_0x63! Can you help me?
      07-30-2023, 07:59 AM   #10
bigpaul6
Drives: BMW F10 520d
kubax86 could you dm me please on help with a TAL failure? Headunit stuck on a bluescreen and getting Tal failure warning and reflash failure. Thanks
1addicts
