10-31-2018, 04:57 AM | #1 |
Rep 628
Tyre pressures - 530d UK
Hi,
my TPM is showing 2.2 on all tyres. I'm going to get pair put in them. They should be reading 2.6. It's been years since I used a tyre pressure machine in a garage and last time I used on it was two digits, eg 36. Can the machines switch to a decimal point system? Thanks, Bal.
G30 530d M Sport xdrive, Adaptive Drive and with all of the important options. |
10-31-2018, 06:14 AM | #2 |
Rep 628
sussed it. I just converted them Surprised though that they can be changed to psi through idrive.
10-31-2018, 06:27 AM | #3 |
2797
Rep 5,115
Yes psi and bar both catered for.
Have mine set to bar. Have a bicycle pump at home that works for the car aswell and simply pump the tyres whilst keeping an eye on the idrive to make sure it's correct. Have a shortcut button aswell so I can instantly see the pressures. With recent temperature changes worth keeping an eye on them as they can end up a bit low if the temperature has dropped since last check. |
11-01-2018, 11:37 AM | #4 | |
Rep 628
Where in the idrive can I change the settings to psi. Thanks.
11-05-2018, 04:47 AM | #6 | |
Rep 628
Thanks.
