BMW M2 Forum > BMW M2 Competition Model > Will Variable Light Distribution (VLD) work on US spec M2?
      05-19-2018, 11:09 PM   #1
YasF80_SLO
YasF80_SLO's Avatar
Drives: F80
2015 BMW M3  [0.00]
2018 Nissan Versa S  [0.00]
As the tile suggests, will Variable Light Distribution work on the US spec M2's easily?
      05-19-2018, 11:12 PM   #2
hellrotm
4143
Drives: F80
Are you referring to Anti-Dazzle?
      05-19-2018, 11:15 PM   #3
YasF80_SLO
YasF80_SLO's Avatar
Drives: F80
2015 BMW M3  [0.00]
yes
      05-19-2018, 11:18 PM   #4
yaymitch
yaymitch's Avatar
868
Drives: 2020 M2CS & 2022 RSQ8
If it's like the current M3/M4, then coding will manage it.
2020 BMW M2CS HS 6MT
2022 Audi RSQ8
      05-19-2018, 11:20 PM   #5
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
BIMMERCODE
Coding for 8S4 (VLD):
Front Electronic Module > Expert Mode >
3073 LaMaster1 > LUT_FLC_FORWARDLIGHTING_Y > 9C,9C,9C (Both)
3073 LaMaster1 > C_AFS_ENA > Enable (Both)
Coding for 5AP (GFHB):
3073 LaMaster1 > C_HBA_ENA > Enable (Both)
3073 LaMaster1 > C_HBA_GRHB_ENA > Highway_Standby_AFS
3073 LaMaster1 > C_HBA_ADAPT_SHUT_ENA > Enable
Note: You'll see two blue check marks next to some of these. Press the top one. It will uncheck the one below it. Now you can enable one of the two 'enable' options (if there are two). Back out. Go back in. Both correct selections should have the blue check mark next to them.
Appreciate 6
hellrotm4142.50
ORIGIN M.3160.50
CSBM52722.50
      05-19-2018, 11:30 PM   #6
hellrotm
4143
Drives: F80
Originally Posted by 2013_E92 View Post
yes
Yes, just option the Adaptive LED and code for Anti Dazzle. I don’t see it being any different from every other model. Anti Dazzle is quite nice.
      05-19-2018, 11:34 PM   #7
AndrewC1989
OP was asking about VLD which isn't the same as anti dazzle (GFHB). They're not interchangeable terms.
See here:
http://f87.bimmerpost.com/forums/sho...8&postcount=10
Appreciate 4
      05-19-2018, 11:38 PM   #8
hellrotm
4143
Drives: F80
See here:
      05-19-2018, 11:45 PM   #9
YasF80_SLO
YasF80_SLO's Avatar
Drives: F80
2015 BMW M3  [0.00]
See here:
Thanks for the clarification, will GFHB be programmable on the M2 competition for the US market, no standard, but can you enable it later?
      05-19-2018, 11:50 PM   #10
AndrewC1989
As long as the ECU/DME doesn't have some brand new encryption no ones seen before then yes you'll be able to enable it right away. If it's new then you'll have to wait till someone cracks it.
I assume it will be identical to the outgoing M3/M4 so you should be good to go.
      05-20-2018, 04:21 AM   #11
akkando
akkando's Avatar
5865
Drives: 17 M2 DCT LBB,11 e90 M3 ZCP IB
yes
Last I looked into it, VLD yes, anti Dazzle? Well some say FOR SURE you can code it, other say FOR SURE you can't and you are just shining high beams at other drivers. The people who say it does work seem to be driving around a little bit and then say from the perspective of the driver seat it works perfect. They didn't bother to ask the other drivers though.
ZPrime611.50
      05-20-2018, 10:11 AM   #12
AndrewC1989
One forum member tested it with a friend driving in front of him and the friend said it was fine. Obviously you should take everything said on here with a grain of salt though.
I have it coded in for fun but hardly ever use it as my M2 is not my DD and I almost never drive it at night.
      05-23-2018, 01:18 AM   #13
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
The current understanding of GFHB (among those of us who have been messing with the settings on NAR-spec M2s with adaptive LEDs) is that the NAR-spec LED headlight modules are missing the proper micro-shutters to correctly mask out "windows" with the lights.
You can turn it on, it seems to work, but you're probably blinding/glaring other people, which makes you an asshole.
If you swap your headlights for ROW-spec, then you'd probably be fine... at a cost of $thousands.
VLD is fine and safe to enable though. Works nicely at lower speed, spreads lower and wider and helps you see stuff in the road or whatnot.
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
CSBM52722.50
      06-01-2018, 04:41 PM   #14
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
So I'm not getting this with bimmercode.
I go into Front Electronic Module > Expert Mode >
3073 LaMaster1 > LUT_FLC_FORWARDLIGHTING_Y > and there is no 9c there are 4 things with the dot you can select but only one.
Am I missing something? I've used Bimmercode many times but never in Expert mode.
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
      06-01-2018, 04:57 PM   #15
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Also my car is Canadian
I have
8S4
Decoding Variable Light Distribution
5AP
Decoding For No-dazzle High-beam As
      06-03-2018, 02:32 PM   #16
CanadianDriver
Drives: P3D-
BIMMERCODE
Thank you andrewc89 for the instructions. VLD is now activated in my car and I’m delighted with the improved illumination. I do a lot of cornering in my regular route and this fits the bill nicely!
m2
