05-07-2018, 01:05 AM | #1 |
Rep 17
Tire temperature variations
Hey all, I just hit 1100 miles today, two weeks after picking up my car! I'm driving easy, back roads, pretty much 100 miles a day for fun. Breaking it in by the book. I have my first service scheduled for Wednesday. I love the car.
Today I noticed my front driver side wheel temp was about 10-15° hotter than the rest. I pulled over to make sure nothing was blocking my vents and didn't find anything obvious. I haven't noticed this big of a variation previously. Any ideas what could cause this? Cold, my tires are all 35psi. What do you recommend? Also, what are normal, spirited, and track driving tire temps? Sorry if I missed this info elsewhere. I searched multiple times with no luck, but I am a noob. Thanks in advance. |
05-07-2018, 01:36 AM | #2 |
Rep 17
Additional info.
Ambiant temps were around 70° Farenheit. I was driving left and right turns equally hard. Tire temps stayed pretty much the same after 30 minutes of easy fwy driving after noticing the hot left front. The fact that the tires shown on the screen get brighter GREEN as the temp rises, is just awesome. Thanks for that sweet touch BMW. Just noticed that. |
05-07-2018, 06:04 AM | #5 |
Rep 40
Mine is the same too. I suspect that it’s due to the supplements radiator in front of the tyre discharging more heat than the oil cooler on the other side.
The tire does physically feel warmer. |
05-07-2018, 07:24 AM | #6 |
Rep 844
I think that is normal since you are sitting on the left side which causes more heat? Also if sun is shining more on the left side can cause the different temps.
05-07-2018, 08:29 AM | #7 |
10739
Rep 6,958
Drives: 2018 M2 AW DCT
And 35 psi all around is the recommended tire pressure.
05-07-2018, 08:43 AM | #8 |
The deuce gets loose
290
Rep 499
yes, as others said, it is the oil cooler that is causing the extra heat. I set all of mine to 35 while cold.. then do a spirited drive for a few miles and then i adjusted them all to the same (37 i think it was when warm). I just had to drop the front drivers 2 psi from the heat.
05-07-2018, 08:56 AM | #9 |
197
Rep 430
Drives: 2017 M2 LBB 6MT; 2012 328i 6MT
Is the supplements radiator in the front left or right looking out from inside the car?
Could this be contributing to 'noisy' tires due to uneven wear? |
05-07-2018, 11:15 AM | #10 |
Rep 254
I think it's due to the Suns location. I see that not only is the front left warmer but also the front rear.
When I'm at the track, I always notice when I'm about to start my next session that one side is always significantly warmer than the other side and it's always the side that had been facing the sun. |
05-07-2018, 12:18 PM | #11 |
Rep 602
Have not noted this difference, but will these next few days/weeks.
One note on being at an event, track related with sun on one side: buy some color matching decent bath towels [they have to match you know] and drape over tires while waiting. Old trick from race days past. Makes your tires all equal when needed. |
