PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Run-Flat repair
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer |
06-20-2005, 02:13 AM | #1 |
Rep 722
Run-Flat repair
Hello,
I just noticed my tire had dropped to 30 psi (didn't trigger the sensor) and upon closer inspection, I noticed a nail in it. It is a very slow leak (3 psi over 2 days) so I am wondering if it is repairable. It is pretty close to the middle of the tread, and I want to make sure that if I have it repaired, that it will be safe. Does anyone have the latest skinny from BMW/Bridgestone? I can't find much online, and there are conflicting posts on this and other forums. Thank you! |
06-20-2005, 04:10 AM | #2 |
Rep 663
CC330i,
I am no tire or run-flat expert but from what I understand, the run-flat ability of your tire hasn't really been used yet. This ability stems from the special construction of the sidewalls in the tires. When there is still 30psi of pressure in the tire there is still, ummm, a lot of air in the tire. It should not be riding on its sidewalls at this point. It doesn't seem to that the sidewall should be damaged by this yet. So if the puncture is something that's patchable then it seems that you could do that ASAP and be okay. Just my $.02
E90 330i delivered 6/29/2005, ZSP/ZPP/ZCW/Step, Arctic/Gray/Walnut
06-20-2005, 11:23 AM | #3 |
Rep 722
I found this online:
http://www.sae.org/automag/features/...-113-4-184.pdf First info directly from Bridgestone that I have seen that states a Bridgestone can be repaired if it has a slow leak! |
06-20-2005, 12:47 PM | #4 |
Rep 722
I had my tire repaired at a local tire shop. They said it was no problem to repair a run-flat as long as the damage was not to the sidewall, and that the tire has not been run on for a long way flat. They inspected it and it looked fine, so they went ahead and repaired it. I will let everyone know if I have problems with it later.
