Converting torque wrench for different drives?
02-27-2018, 09:25 AM | #1 |
Rep 40
Beginner here. I'm still learning a lot about tools, mechanics and such.
I'm about to order a torque wrench, but wanted to make sure of something. The socket I have is 5/8ths drive. The wrench I want to order has 1/2 inch. There are adapters which can compensate for this difference, yes? In other words, using the 1/2 torque wrench with a 5/8 socket via a compatible adapter. Any other pointers would be appreciated - thanks for your patience. |
02-27-2018, 10:54 AM | #2 |
Life is better with burnouts
99
Rep 611
Drives: BMW
On a socket there are two ends. One is the drive end and one is the end for the bolt head. The drive ends can be 1/4 3/8 1/2 3/4 in etc. The bolt head side of your socket is 5/8. The other end is going to be 1/4 3/8 1/2 3/4 in etc.
Deutschophile11.00 Efthreeoh17424.50 |
03-01-2018, 09:26 PM | #3 | |
17425
Rep 18,801
The "drive" end of a socket is square. The hex side (i.e. what goes on the head of the bolt) is either Hexagonal (six-sided) or 12-sided. As TheeGovernor stated, the standard drive sizes for common hand tools are 1/4-inch, 3/8-inch, 1/2-inch, 3/4-inch, and 1-inch. Meaning, there is no 5/8-inch drive for common hand tools. 3/4-inch and 1-inch drives are used mostly for repairs on heavy equipment or large trucks. Now, there are adapters to allow use of different drive sized sockets with different-sized drive tools (i.e. a ratchet or torque wrench). BTW, BMWs are built to metric specification so they use Metric-sized fasteners. A 5/8th socket is an "American" or "SAE"(Society of Automotive Engineers) size tool and not meant to be used on a BMW. That said, for probably the last 35 years or more most all American brand cars (GM, Ford, Chrysler) are also built to metric standards. No offense, but your question (if not trolling) is seriously noobish, so I have to ask, why are you buying a torque wrench anyway.
Deutschophile11.00 |
03-01-2018, 11:37 PM | #4 | |
Rep 40
I'm buying a torque wrench to properly torque spark plugs. I want to take very good care of my car in a lot of ways. A torque wrench is a good tool to have if doing repairs, maintenance, etc. Appreciate the explanation. |
03-02-2018, 07:26 AM | #5 | |
17425
Rep 18,801
03-02-2018, 09:20 AM | #6 |
2183
Rep 2,806
Why do you recommend beam style v clicker?
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
03-02-2018, 10:43 AM | #7 |
17425
Rep 18,801
Because the torque spec for plugs is between 18 to 25 lb.-ft. Most click-type 3/8-drive torque wrenches have a range of 15 to 100 lb.-ft. but they are inaccurate at lower torque settings. Click-types are the most accurate in the middle of their torque range. 3/8-drive beam torque wrench is accurate all the way down to 0 lb.-ft. Beam type wrenches have no mechanism to go out of calibration.
3/8 and 1/2-drive click-type wrenches are cool and all, but inaccurate for torquing at low settings. I use a 1/2-drive torque wrench for wheel bolts mostly and big bolts like subframe, hub nuts, etc. Spark plugs you should use a beam style. Last edited by Efthreeoh; 03-02-2018 at 10:52 AM.. |
Meeni329.00 |
03-02-2018, 10:55 AM | #8 | |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
Usually how it goes
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
Meeni329.00 |
03-02-2018, 11:45 AM | #9 | |
2183
Rep 2,806
Thanks,
03-02-2018, 12:07 PM | #10 |
2183
Rep 2,806
One thing to add for the OP is that adapters don't effect the accuracy IF they are not changing the length of the wrench beam (the adapter is not a horizontal extension).
03-02-2018, 04:03 PM | #11 |
17425
Rep 18,801
02-04-2020, 11:27 PM | #13 |
Rep 5
hi everyone, i'm planning to rebuild my engine and looking to buy a new torque wrench. Anyone can suggest me on this list https://marathonmodular.com.au/servi...ar-classrooms/, the best torque wrench for this job when it comes to price and durability. I appreciate all who will comment. thanks
Tags |
adapter, torque wrench |
