BMW M2 Forum > Regional Forums > UK > Interior carbon trim ?
      01-04-2018, 06:59 AM   #1
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
I have fitted the interior carbon trim today, it took approx 40mins and that's taking my time. It make a big difference and flows with all the carbon
First 2 pics are after I did the Job, 3rd pic is a stock pic.
I started with the hand break, you have to pull it off, so I started with the hand break just in case I damaged the DCT carbon trim
Next I used a very small flat head screw driver on the DCT logo centre piece, I wedged it in and rocked it up and down and I could see and hear the glue parting from the silver DCT trim. The rest was easy, a little screw and the silver trim removed.
Trim around the DCT, here is a tip and found it made it easy and no damage, use a trim tool or a small screw driver on the inside not the outer edge. I pushed the DCT in reverse and pushed the tool in the inner section and it pushed the trim up and our with out any damage .
Sorry I was intending to take pics at stages but it was cold and I just wanted it done. Sorry
M2 = big smile every time
      01-04-2018, 11:24 AM   #2
toml
Drives: M2
Pics?
      01-04-2018, 12:30 PM   #3
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Originally Posted by toml View Post
Pics?
Pics above, pics are after doing the job
      01-04-2018, 12:44 PM   #4
azibux1
United Kingdom
42
Drives: M2 LCI
I can't see them?
      01-04-2018, 12:47 PM   #5
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
I can't see them?
How about now
      01-04-2018, 02:23 PM   #6
azibux1
United Kingdom
42
Drives: M2 LCI
Looking good! That alctantara bit new too? All OEM?
      01-04-2018, 02:31 PM   #7
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Yes all OEM, I don't like the idea of adding third party parts. If I was buying a used M2 and it had third party parts on, I would give it a miss.
ryzer3021.00
as7920597.00
      01-04-2018, 02:46 PM   #8
toml
Drives: M2
Looks fantastic!
      01-04-2018, 02:47 PM   #9
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Looks fantastic!
Thanks, makes a big difference
      01-04-2018, 04:03 PM   #10
azibux1
United Kingdom
42
Drives: M2 LCI
Ah nice!
Did you get a good discount from anywhere or was it retail? Mind sharing the dealer please if it was discounted?
      01-04-2018, 04:18 PM   #11
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Ah nice!
Send you a pm
      01-21-2018, 10:23 AM   #12
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
I have just ordered the carbon trim for the steering wheel. Bargain £175 from a BMW dealer on eBay
      01-24-2018, 07:11 AM   #13
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Just fitted steering wheel carbon trim. From start to finish approx 30mins. Finishes off the cockpit. What do you think
JustChris17487.50
      01-24-2018, 08:55 AM   #14
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
How to likes for interior carbon trim and steering wheel trim
IND | BMW M Performance Carbon Interior Kit DIY http://f87.bimmerpost.com/forums/sho....php?t=1274653
http://f87.bimmerpost.com/forums/sho....php?t=1441855
M2 UKM12.00
      01-24-2018, 11:45 AM   #15
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
I have had a number of messages asking where I got the carbon from.
You can buy from your local dealer but they can be very expensive.
Search Ebay uk you will find a couple of BMW dealers selling at discounted price.
I got the DCT carbon set for £295 free Delivery, local dealer could match this price but I would have to collect. Normal price is £400
Steering wheel carbon trim was a bargain £175, a dealer had 2 and they went straight away. There is a couple of dealers selling for £225 free Delivery. Normal price £300.
Very easy to install, just take your time .
      03-12-2018, 12:34 PM   #16
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
I have a number of members asking if you can remove the carbon, I have attached a photo of the underside. As you can see you could remove the carbon if you remove the metal rings
      03-12-2018, 12:46 PM   #17
as7920
as7920's Avatar
United Kingdom
597
Drives: 2023 SG/FR M4 xDrive Competiti
Fitted 2 pieces of mine at the weekend, however, I got stuck on the DCT gear lever. Stubborn plastic trim means I now have a damaged shifter, and its still the original.
I tried tiny flat head (i.e. glasses repair), a larger one and I'm still stuck. Any additional advice?
I've watched a number of You Tube videos including IND and I'm doing nothing different.
All the discount I got on the parts is now wiped out by having to replacing the damaged part FFS. Grrr.
      03-12-2018, 12:47 PM   #18
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I'm stilling thinking of moving the carbon to the factor plastic insert.
For those thinking of doing this, use a pair of dikes and cut the rings off and reinstall w/new rings.
      03-12-2018, 12:48 PM   #19
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
See post #17... http://f87.bimmerpost.com/forums/sho...ghlight=dental
as7920597.00
      03-12-2018, 12:55 PM   #20
as7920
as7920's Avatar
United Kingdom
597
Originally Posted by omasou View Post
You know what, I swear I read that post, either for fitting this or for the last time when fitting or removing the same kit for my M135i, however I seem to have missed the DCT Shifter removal.
I've got a similar plastic trim tool and will try that.
Cheers.
      03-12-2018, 01:07 PM   #21
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Cheers.
NO! Use dental floss.
as7920597.00
      03-12-2018, 01:14 PM   #22
Wilsm2
Mini Beast
Wilsm2's Avatar
United Kingdom
188
Drives: 2018
Cheers.
Hi
I did put some info at the beginning of the thread, i hope this helps you more.
I pushed the trim tool in the gap of the trim and the DCT gear leave (red arrow) on photo , you will see the front of the trim bend up and un hook.
m2
