E90 fob battery Change ( but need reprogramming)
11-08-2017, 09:27 PM | #1 |
Rep 276
NON-CA. So I've been searching around and I only find options for programming it blank key fob. Now my situation is I removed the old battery solder a new battery. The car turns on and everything just doesn't lock and unlock. With my spare key it does lock and unlock no problem. so I'm figuring I need to reprogram The key sense I removed the battery and installed a new battery on the fog. Any suggestions . Thank you
11-08-2017, 11:28 PM | #2 |
1920
Rep 13,122
11-09-2017, 12:15 AM | #3 | |
Rep 276
11-09-2017, 01:20 AM | #4 |
1920
Rep 13,122
But does the new battery have a charge .
Its rechargeable if you put the right one in. Did you measure the voltage ? Read everything by Mashman in the key article. I don't think it should require reprogramming, mine sure doesn't when I change the battery on it but it is a CA Fob. Mine warns me of a low battery when it gets low. |
11-09-2017, 02:26 AM | #5 | |
Rep 276
11-09-2017, 02:49 AM | #6 |
1920
Rep 13,122
https://www.bmwgm5.com/
open and click on diamond key fob repair for and an explanation on what could be wrong or send that guy and email. |
11-09-2017, 11:59 AM | #7 | |
Rep 276
11-09-2017, 03:08 PM | #9 | |
Rep 276
But to just roll out the idea that the key would need to be reprogrammed, there really ain't any information of doing that right |
11-09-2017, 04:17 PM | #10 |
1920
Rep 13,122
If you read mashman's response especially entry 13 he lays out all
the technical stuff on the keyfob .(in the first link) Also Bimmergeeks can program a new Fob . I think they charge 200 but that is not with a cut key for manual operation. |
