M2 Technical Topics > Suspension | Brakes | Chassis > Ohlin Spring Rates-Alternatives
      09-26-2017, 07:39 PM   #1
Saanen
Saanen's Avatar
Drives: M2 BSM 6SPD, VW e Golf (DD)
I am curious what options there are to soften things up. Specifically I am curious if anyone has spec'd their M2 with Ohlins at a lower spring rate?
I am contemplating running them with 80N/mm for the front springs and 170 (or 160)N/mm on the rear. Has anyone else run a setup like this?
If I understand things the Ohlins are excellent in quality and performance but a little stiff for those of us that spend most of our time on the back roads and canyons; and street. On the M4 forum folks have swapped from 230N/mm rear to the lower spring rate offered for the M2= 190 N/mm springs in the rear and seem to like the result. Given that the M4 is a slightly heavier car it seems that softer springs might be ideal for true street and canyon use on the M2.
I contacted Jake at Ohlins and he responded...
"You can spec your rear spring as you see fit, however, our spring choice is a bit limited over the 120N/mm rate. 80N/mm will not be a problem. However, above the 120, we have the 190 and the 220 -that’s it. You are welcomed to purchase two aftermarket 170N/mm springs..... The 190N/mm stock rate is definitely on the racier side, so your 170N/mm totally within the range. What a lot of other people have been doing is lowering the rears rates to 160N/mm and keeping the front 90N/mm springs. But you can chose whatever (front) rates you would like. Thanks!"
So with that combined with the TC Kline coil over spring rates of 60N/mm front and 105 N/mm rear ; totally different valving I realize, but still it seems softer might be reasonable.
What do you guys think?????
2017 BMW M2 BSM 6spd with Fabspeed/HJS 300 cell Sportcat, BM3 OTS Stg 2 tune, Dinan Turbo, MST V2 Inlet, Dinan IC, Dinan CAI, Ohlins, Carbon Fiber+Aluminum Strut braces.
2007 BMW 335i (sold); 1997 BMW E36 M3 (sold);
1988 BMW 535is (sold); 1984 BMW 323i Alpina (can't believe I sold),1969 BMW 2002 Ti (spec'd as Ti; and yes I sold this too...).
      09-30-2017, 08:09 AM   #2
BurpZilla
Avid Car Enthusiast
BurpZilla's Avatar
Drives: 2017 Alpine White M2 6spd
What are the best settings for daily that?s a little hard so I would still enjoy track days without adjusting too much?
History will never be forgotten
1992 Red Acura Legend 4dr, 2003 Daytona Blue Nissan, 350z 6spd, 2007 Black Audi B7 RS4 6spd
Current Girlfriends
Alpine White BMW M2 6spd; 2015 Arctic White Yukon XL Denali
m2
