E90Post
TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > E90 328xi DIY for many items
Reply
      09-10-2017, 09:10 PM   #1
merz.38
Drives: 2007 328xi. 6MT
Hello E90 post community, I use these forums frequently for technical information and don't post on things as much as I should. There isn't a huge amount of support available for the xi model cars it doesn't seem like. So I wanted to do a write up for a major job I just completed. It turned into somewhat of a charlie foxtrot so I may have glossed over some things because the job took significantly longer than I would have liked. In any case I Will cover in this write up how to do:
o Jack up and position vehicle for service
o Serpentine Belt replacement
o Front Swaybar replacement
o Hubcap replacement
o UUC short shift kit for 328xi
o Shift Knob replacement
o Transmission fluid flush
o Front Differential fluid flush
o Rear Differential Fluid Flush
o Coolant flush and drain plug replacement
o Front brake caliper/pad/rotor replacement (335xi brake upgrade)
o Rear brake caliper/pad/rotor replacement (335xi brake upgrade)
o UUC stainless steel brake hose replacement
o Parking brake replacement
o Front Wheel Bearing Replacement
o Rear Wheel Bearing replacement
o Crank shaft position sensor
o Intake manifold gasket replacement
o Valve cover / valve cover gasket replacement
o Ignition coil removal and replacement
o Spark plug replacement
o Most of the work required to change your starter motor
o Most of the work for replacing the eccentric shaft position sensor
** I added a new PDF write-up on 4/24/2018
Some of the things I may move quickly through and there could be a few typos here or there. Hopefully this helps some people.
File Type: pdf Compressed diy for c pos sens int manf vcg etc.pdf (3.60 MB, 251 views)
Appreciate 5
rohitsja232.50
Greyfox1207.50
tsm00764.50
Paco4.00
      09-18-2017, 10:56 AM   #2
ArfMeow
ArfMeow's Avatar
16
Drives: BMW 328i
2009 BMW 328  [0.00]
      09-25-2017, 11:40 AM   #3
Jagaer
430
Drives: 2011 E91 328xi 6MT
Lots of great info to supplement the Bentley.
Thanks,
      10-02-2017, 10:50 AM   #4
zoli.bee
zoli.bee's Avatar
Slovakia
Drives: n54 & n52
2007 e91 330xi  [0.00]
2008 e92 335xi  [0.00]
thx man
      04-25-2018, 10:43 PM   #5
merz.38
I have made a DIY for the additional following items:
File Type: pdf Compressed diy for c pos sens int manf vcg etc.pdf (3.60 MB, 176 views)
Reply
Tags
328xi, diy, high mileage, repair, upgrade
e90post
