One touch up for my front windows stopped working
09-05-2017, 02:12 PM | #1 |
Rep 1,076
Drives: 07 335i e93 6MT
Hey guys, I've searched and the window reset procedure does nothing. I have an e93 so i can't even open my top without lowering the front windows first. I got a new ecu put in a while back and it started happening then. One touch down works but up does not. Anyone come across this issue? Could it be a coding issue? I did have an indy shop try to see if it's coding, but they couldn't figure it out.
07 BMW 335i E93 6MT (Praying neighborhood doesn't get flooded...again) 04 Infiniti G35 Coupe 6MT (Flooded) 08 Audi TT 2.0T DSG (Flooded) 03 Subaru WRX 5MT (Flooded) |
09-06-2017, 01:18 PM | #2 |
Rep 1,076
Bump. Any input would be appreciated!
09-07-2017, 01:16 AM | #3 |
1920
Rep 13,122
There is and initialization procedure somewhere if that doesn't work
you may need the FRM module or CAS reprogrammed. Was that the module that was replaced? My guess is the e93 will require special programming you might try the coding sub forum http://www.e90post.com/forums/forumdisplay.php?f=368 Talk to Bimmergeeks about a remote coding session. https://www.google.com/url?sa=t&rct=...GygM2UEaf_Vpuw http://www.bimmerfest.com/forums/sho...d.php?t=650490 There is some debate on what works in the last thread so read all the entrys. Last edited by ctuna; 09-07-2017 at 01:36 AM.. |
09-08-2017, 01:58 PM | #4 | |
Rep 1,076
