DIY Ram Air Scoops
05-06-2008, 12:28 AM | #1 |
Rep 15
DIY Ram Air Scoops
Wanted to give back for all the useful info I've found on this site. I decied to make my own ram air scoops that go behind the grills and now i want to share.
I searched for ideas and found a couple of good ones but wanted to do something faster, cheaper, and simlpe. I decided to mount the scoops to the snorkle and avoid drilling any extra holes. I wanted it to be easy to instal and remove if need be. You dont even need to remove the grills, just the two torx srews and the two plastic rivets. The air deflector comes in two peices. I cut off the magnets that mount itself to an A/C vent and trimed off the sliding tabs to make the scoops semetrical to each other. Parts: Air Deflector (any hardware store): $6, 3M double sided tape: $3, price for more cooler air...priceless. Tools: Dremil, file, lighter to melt and clean the cut edges. Sorry,wasnt able to take pictures of the acttual cutting of the air deflectors but hope the pictures help. I used a table belt/drum sander to remove material and used blue tape to cover areas i didnt want scratched. If you can tell i double sided taped the scoops to the inside of the snorkle but i also added a couple drops of hot glue (or shoe goo) to add strength. You do have the options to paint it but i oppted not to. Ive had it on for a couple of days now and no problems. Good luck and enjoy! |
05-06-2008, 12:34 AM | #2 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
pretty nice!
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
05-06-2008, 01:00 AM | #5 |
boku no namae ha...
336
Rep 11,025
haha +1whp?
05-06-2008, 02:29 AM | #7 |
Da Kid
121
Rep 4,576
thats very nicely done!
MODS: OEM Front Splitter | ACS Roof Spoiler | OEM Trunk Spoiler | Matt Black Front Grill | Black Shadowline Window Trim | Painted Front Lower Rod | Blacklines | JDM Yellow Fogs | Custom Silver CF Headlights with LUX 4.0 | Eisenhaus Sports Exhaust |
05-06-2008, 02:55 AM | #9 |
Aberry is a scammer
559
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
wow, I have one of these right under my desk!, (I'm touching it with my foot to make sure its there ) hmm interesting! have any plans on painting it black?
05-06-2008, 04:27 AM | #10 |
57
Rep 590
Great Idea!
Now test it at speeds +150 mph and hold for atleast 3 mins then come back and tell us how it held up.. BTW the you'll notice the air scoop gains at speeds above +90 mph.
05-06-2008, 04:54 AM | #11 |
749
Rep 2,108
isn't that blocking too much air that would usually go to the radiator? thats the radiator behind the scoops right?
Is it fine this way? and has actually anyone done any dyno testing or data logging to prove that these air scoops actually work? |
05-06-2008, 10:08 AM | #13 |
Rep 15
I dont think its blocking too much air to the radiator. I dont recall anyone doing a dyno yet. I just did it for fun. I figure more air is better than no air. I think the only down side is a dirty airfilter. I have the air aiming at my two K&N cone filters. Now I know that helps!
05-06-2008, 10:14 AM | #14 |
Rep 15
Nah, I'll keep it clear. If anything i might drills holes if im not getting enough air to the radiator but i think its ok.
05-06-2008, 11:06 AM | #15 |
Rep 308
Dont worry about the air to the radiator, it is only sucking it up from the top. What we should be worried about is how there is barely no air going into that snorkel without a mod like this.
05-06-2008, 12:36 PM | #16 |
143
Rep 6,333
any difference?
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
05-06-2008, 04:21 PM | #17 |
Rep 993
Drives: F85
Nice install! Looks like one of those "might-as-well" mods that may or may not be effective, but can't really hurt either. And it looks like fun to do!
EDIT: O wait, what if I've got these on and am driving through heavy rain? Won't the water slowly make it's way to the air filter and then eventually soak through? Could that be why the stock ones are facing downwards? |
05-06-2008, 04:29 PM | #18 | |
Rep 15
I though about that too and while washing the car with a pressure washer. I noticed at the bottom of the stock air box a drain hole for moisture. I dont think the the air is being pulled enough to soak through the filter. I however have it aiming towards my two K&N filter. I'll find out the first day of rain. |
07-15-2008, 09:38 PM | #19 |
Not looking 2 SPEED, just looking GOOD
45
Rep 2,516
This is what I am looking for! I bought a Grupe-M that had no scoop and paid $190 for it so I am so doing this!
07-23-2008, 02:27 AM | #22 |
45
Rep 2,516
I made it more easy by putting the scoops where the opening is like the supreme did. I didn't do much of the cutting just clip the areas to let it set in and just apply bondo. Been on for over a week and I drive 85-110mph on it so far and it does scoop into my closed Grupe-m air box. Good excelleration gain. Not alot of noise. Best performance mod ever! Thank you roderick335i!!!
