2010 2011 BMW 5 Series Forum F10 2012 535i F10 water pump error |
06-21-2017, 10:20 AM | #1 |
Rep 15
Has anyone had an issue where the water pump would not start or error on a cold start and then start once the car is turned off and restarted?
It's happened to me twice now, when I start in the morning the fan runs at high-speed, I get a high temperature light, pullover to the side of the road and turn off the car for three or four minutes. When I restart the car the water pump then works. I know it's the water pump not working because when I turn the heat all the way to hot it blows out cool air. As soon as I restart the car, he will begin blowing hot again. |
06-21-2017, 11:21 PM | #2 |
Rep 76
It could be thermostat and/or water pump. I would replace both before you get your engine overheated. It may stop working while you are driving at high speed, causing more damage as temp climes up.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
