2010 2011 BMW 5 Series Forum F10 Retrofitting PDC - Cost and Parts |
05-25-2017, 03:03 PM | #1 |
Rep 192
Drives: 2016 Alpine White 528i
Hi fellow forum members. I hope you are doing good. I was hoping to get some information for retrofitting PDC. My car is a BASE 528i and doesn't really have any options. I was looking to add PDC to the car and probably want to DIY it. I've tried to search up some stuff but haven't run across anything concrete for the F10 in particular.
My first concern is cost. I tried to search up the sensors and I'm finding prices of $200+ per sensor. If that's the case then I'm dropping the whole idea. Also would anyone be able to point me to additional parts I would need. I believe I need the sensors, the brackets, and the wiring. Will I also need a ECU? Also what other parts would I need. I appreciate any input or direction to the correct thread if it's already been discussed. Thank you for looking! |
05-25-2017, 03:08 PM | #2 | |
Rep 57
05-25-2017, 03:39 PM | #3 |
Rep 192
05-25-2017, 04:26 PM | #5 |
Rep 192
05-25-2017, 07:17 PM | #6 |
936
Rep 4,327
Drives: M340
Find a wrecked car and that route would be much cheaper.
Most of everything is plug and play and then some coding. Luck is on your side as most F10s have parking sensors, so it should not be that difficult to get one.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
05-26-2017, 12:04 PM | #7 |
Rep 192
That's actually a great idea. Thanks for the suggestion. I'll try to find some junk yards who have what I need.
05-27-2017, 12:42 PM | #8 |
Rep 192
Does anyone have any recommendations for where I can find a wrecked car. I've tried calling a handful of salvage yards around me and I'm falling short every time.
05-28-2017, 10:13 PM | #9 |
4528
Rep 5,379
05-29-2017, 01:44 PM | #10 | |
Rep 192
If someone could clarify for me, is rear PDC required for backup camera. I've read that in a lot of places and don't want to end up retrofitting a backup cam and if not working. |
05-29-2017, 07:05 PM | #11 |
Rep 76
Rear Camera is a standalone option. My car has neither PDC nor Backup Camera. I have retrofitted backup camera only.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
05-29-2017, 07:44 PM | #12 |
Rep 192
Yeah that's what makes sense to me but for example bimmertech says that you have to have pdc for the oem pack. If you don't mind me asking where did you get your parts from. Cost?
05-29-2017, 10:11 PM | #13 |
Rep 231
Quote BimmerTech for a rear view camera retrofit kit (MMI, no coding). I installed one and it works great.
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
05-29-2017, 11:13 PM | #15 | |
4528
Rep 5,379
05-30-2017, 10:47 AM | #16 | |
Rep 192
I assume you are talking about the Halos of the car and in the case of the F10 platform all halos are round if I'm not mistaken. Even on the LED pack, the Halos are going to be rounded. |
05-30-2017, 11:57 AM | #17 |
4528
Rep 5,379
AFAIK the LEDs are a different shape. Check autotrader and such for pictures.
05-30-2017, 07:15 PM | #18 | |
Rep 6
05-30-2017, 10:13 PM | #19 |
Rep 231
It has a full screen HD video. I like it better than the OEM's look.
05-31-2017, 03:55 PM | #20 | ||
Rep 192
05-31-2017, 04:12 PM | #21 | |
Rep 192
05-28-2019, 10:47 PM | #22 | ||
59
Rep 590
