M2 Technical Topics > Cosmetic Modifications > M LED Door Projector Lights
      04-20-2017, 05:42 AM   #1
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
Lightbulb M LED Door Projector Lights
I got M door projector lights installed from the port and I must say I'm disappointed in the quality of work put in. The M logo isn't line up straight when the doors are open. On top of that I found out the lights were installed the wrong way.
Anyone who has these lights installed can you confirm that the lens is farther away from the hood vs being closer. I noticed to get the lights lined up for driver side you have to adjust the lens moving it up about 40 degrees. As for the passenger door it's about around the middle so not much adjustment is needed.
      04-20-2017, 07:29 AM   #2
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Try laying them in a bowl of rice, should fix it
      04-24-2017, 02:05 PM   #3
mjsaville
United Kingdom
101
Drives: M2 LLB - Arrived 4th Mar 2017
I fitted a set of these to the car, and actually they are fairly decent. The rice comment is probably not required. The official BMW ones are horrendously expensive I purchased a set from Aliexpress, and the M Logo is adjustable, i.e. it can rotate so should line up as you like it.
I would suggest having a dig about with a trim tool and see if you can alter them.
The other thing that's bugging me at the moment is the yellow interior led lights which I don't like. I'm considering swapping them out for white led's Bmw do packs of 4 and 8 but the 8's are around $100 dollars I think.
MJ
      04-27-2017, 09:13 AM   #4
MR.
MR.'s Avatar
4399
Drives: BMW M2 CSL Turbomeister
Originally Posted by mjsaville View Post
I fitted a set of these to the car, and actually they are fairly decent. The rice comment is probably not required. The official BMW ones are horrendously expensive a purchased a set from Aliexpress, and the M Logo is adjustable, i.e. it can rotate so should line up as you like it.
The other thing that's bugging me at he moment is the yellow interior led lights which I don't like. I'm considering swapping them out for white led's bmw do packs of 4 and 8 but the 8's are around $100 dollars I think.
MJ
I had one of those Ali Express ones in my MINI GP2 and it burned through... I have a photo somewhere of the original one and the one from Ali Express which just burned completely. I would not be to happy to have my car door on fire due to cheap ass stuff from China
I got the OEM ones from BMW and they work fine. I do not see the problem. I aligned them well and all is well. Looks nice in the M2.
MR
      04-27-2017, 04:19 PM   #5
mjsaville
United Kingdom
101
Good to hear.....
m2
