04-16-2017, 05:21 PM | #1 |
602
Rep 424
Wolfgang Paint Enhancer and Deep Gloss Paint Sealant
Before you spend large sums coating, try this process first. Just finished my BSM. Compared to a friend's Opticoat, neither of us can tell the difference. If your car is not a DD, I would recommend trying before coating.
2018 M4 convertible SBM
1990 E30 Convertible 2003 E39 |
04-30-2017, 10:27 AM | #3 |
Rep 617
I've been using the Wolfgang Deep Gloss Paint Sealant and topping it with Wolfgang Fuzion Wax for the past 8~ years or so. Awesome combo.
I recently applied Dr Beasley's Nano Resin to my vehicle and it turned out great as well. I will most likely be moving forward with the Nano Resin application for future use. It is a great option because it is a coating you can do yourself, lasts 2-3 years depending on your environment. Con is the process of applying and the time frame to cure after, but it's worth it. |
05-01-2017, 06:38 AM | #5 |
Rep 257
Coating
This is an alternate method of protection, but not a coating. So visually, you may be correct that you cannot see any difference with the Opticoat, but the OPC is a true coating, and would not have to be reapplied later.
