03-16-2017, 01:13 PM | #1 |
Rep 11
Replacing Brake Light/ Turn Signal Short
Had to fix an electrical shirt in driver brake light and blinker. The issue came and went but I was obvious it needed to be replaced. I'm attaching a pic of the 2 parts I needed.
The process was an easy unclip and replace the black plastic piece that goes on the tail light. As for the wiring, it was a little tricky. I cut all of the wires feeding the black clamp. Then I clamped the silver parts provided in the kit after I slid on the rubber plugs. Tedious and prob 30 min minimum of wiring. Didn't get a labor quote from dealer but figured it was worth doing myself. Don't forget to unplug your battery. |
