03-11-2017, 04:24 PM | #1 |
Rep 1,447
Front seat removal requires battery unplugging?
Planning to do a through vaccum under the seat. After a bit of googling, I bought a Torx 50 bit for unscrewing. However, i saw someone talks about unplugging battery before removing seat. Can I avoid that by not pulling the wire under the seat?? I just want to clean it up
03-11-2017, 05:24 PM | #2 |
8279
Rep 16,142
You shouldn't have to disconnect the battery. I see it recommended for just about any kind of work that involves the electrical system, probably to save fools from damaging something that they probably shouldn't be working on in the first place.
I wouldn't remove the seat, it moves far enough in either direction that you can get at everywhere underneath it to vacuum. |
03-11-2017, 05:35 PM | #3 | |
Rep 1,447
03-11-2017, 09:00 PM | #5 |
Rep 1,447
Hypothetically, if I decide to take the passenger seat out out for a while, storage, just for fun, whatever the reason is, do i have to disconnect battery before i unplug seat wire underneath in order to put it back someday and still expect it functions normally
03-11-2017, 09:08 PM | #6 |
8279
Rep 16,142
I don't see any reason why you can't unplug the connections. Even if there was some fault for who knows what reason that's why everything is fused.
03-11-2017, 09:11 PM | #7 |
Rep 1,447
Ok..i did just unplug some wires when i wrap interior trims multiple time. no issues. Why anyone would suggest disconnecting battery???
03-11-2017, 09:15 PM | #8 | |
Rep 396
Not sure if that applies to F30's or not. |
03-12-2017, 10:09 AM | #9 | |
8279
Rep 16,142
After disconnecting anything the system might throw a warning when the ignition is turned on, but it should go away after plugging it back in again. If in doubt consult a tech manual. |
03-12-2017, 12:40 PM | #10 |
508
Rep 2,981
Drives: 2013 BMW F30 EBII
I had always read where you were "supposed" to unhook the negative terminal on the battery for the above mentioned SRS issue, but I am not sure either. I am about to pull mine out to do some custom work on the seats...I will probably unhook to be on the safe side...
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
03-12-2017, 04:48 PM | #11 | |
Rep 396
People disconnect seats for whatever reason and then absentmindedly turn the car ON to do whatever. It's best to just disconnect the battery and save yourself the trouble. |
03-12-2017, 07:19 PM | #12 | |
998
Rep 2,214
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining Last edited by John in VA; 03-12-2017 at 09:51 PM.. |
03-12-2017, 09:16 PM | #13 |
Gettin It Figured Out
1823
Rep 2,669
Definitely unplug neg terminal, will throw a code if you don't. Removed my pass. seat when I added a circuit, forgot I still had car hooked up to tender. Erased code with my bm3 app
03-12-2017, 10:55 PM | #14 |
Rep 1,447
I just have the vaccum work done without unplug the seat wire. That wire is long enough for me to lean back the whole seat to have opening for vaccum.
03-12-2017, 10:56 PM | #15 | |
Rep 1,447
03-14-2017, 04:11 AM | #16 |
Schmollbraten
12514
Rep 1,985
Lazy bone! Unscrewing the 4 bolts is a matter of 5 minutes, also with the ratchet
Had them tilted during Bavsound subwoofer installation but not unplugged the receptacles under seat. If you consider to remove them for better installation of the valve, disconnect the battery, wait a few minutes and then unplug. As written here previous, the failure message couldnt be reset by you but the dealer.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
03-14-2017, 03:04 PM | #17 | |
Rep 1,447
Dang3r12514.00 |
