F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 340 B58 PURE STAGE 1 Turbo Testing
proTUNING Freaks
      11-15-2016, 09:18 PM   #1
Mike@N54Tuning.com
4918
Drives: 2007 335i, 2015 M3
Saw this posted so figured I would share.
BMS just got their 2016 340i B58 back from PURE with the Stage1 turbo. The test vehicle is running the JB4, BMS B58 intake, BMS WMI, and PURE S1 turbo. Exhaust and emissions equipment all 100% unmodified. Boost juice and ~95 octane.
Boost up to about 23PSI.
      11-15-2016, 09:23 PM   #2
BimmerSales340
65
Drives: 2016 MSport 340
Interested to see how the car does without WMI and downpipe.
      11-15-2016, 09:38 PM   #3
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
good stuff
      11-15-2016, 09:39 PM   #4
Mike@N54Tuning.com
4918
This car has the factory downpipe and exhaust. WMI is required for the fueling end though. There is an injector IPW hard cap in the DME around 400whp. You can push over that but run leaner as you go. That is where the WMI comes in.
Mike
      11-15-2016, 09:51 PM   #5
jpsimon
Team Zissou
jpsimon's Avatar
Hopefully a flash comes out sooner than later to help remove that cap
      11-16-2016, 01:17 PM   #6
FeelinBlessed
FeelinBlessed's Avatar
227
Drives: 2017 340i AW MPPSK/Track
2017 BMW  [0.00]
awesome!
///MPPSK///MP FRONT SPLITTER///MP KIDNEY GRILLS///CF MIRRORS///CF SPOILER///CF TIPS///HUPER OPTIK 20%///NBT///AC SCHNITZER///M4 437M///ZMP///ZTR///iND///
      11-16-2016, 02:38 PM   #7
boosted
enthusiast
boosted's Avatar
Drives: 2018 340i x-drive 8AT
I've seen crazy numbers for F80 M3. I believe Pure modify turbo internals while keeping the casing stock.
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph.
      11-18-2016, 07:59 PM   #8
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
Wonder why its only seeing 0 (or probably -2 or -4) degrees of timing advance in the mid range. I know the AFR is in the "acceptable range" but its certainly on the edge for a motor pushing that much power. I wouldn't be super comfortable with it...
Either way, very impressive numbers for this new platform. Awesome!
f30post
